Mickey Richaud Mickey Richaud Townsend TN (198 posts) Registered: 08/25/2015 06:36AM Main British Car: '03 Jaguar XK8 Jaguar 4.2 |
Re: Excessive oil burn as of May 2
Bummer indeed. Valve guides? Crankcase ventilation?
Possibly the rings were put in upside down. Rare but I have seen this happen. Where are you located, and how experienced is your engine builder with these engines? As far as the lifter tap is concerned, first what is your oil pressure at idle and cruising? What oiling mods were done when the engine was built, and what are the bearing clearances? And then what was done to set pushrod preload? If you can get those answers we might be able to assist.
Jim I cannot overstress how important it is to either use a knowledgeable and experienced builder who knows these engines intimately, or learn the critical information yourself. Building one like any other typical American V8 is likely to bring disappointment. |
Thanks Jim and Mickey, any help will be much appreciated with this.My good friend Chuck has been putting this car together all winter. It is a lovely 78 B that was just begging for a nice little 215.The result has been more than disappointing!!! I am feeling really badly for Chuck, it seemed like everything was going well......most parts purchased through D&D, the engine builder has been in business for many years putting together American Muscle cars......now the happy little dream project has turned into a horrific nightmare. Has this ever happened to you? Thanks for your thoughts and input! |
It can happen. First step, check your EGR plumbing as that is an easy check and a simple fix. Just take a drive with the oil filler cap removed and see if it makes any difference. If not, (drive far enough that you can really be certain, not just around the block) you can check that off your list of possible causes.
We can't really jump to the assumption that everything was done right until some testing is done. It would help us if you would tell what your oil pressure is, just to get a handle on how well the engine was built, as that is a pretty good indicator of attention to the small details that make a good build. So your next test is going to be compression and leak-down testing. We need to know your static compression ratio and the compression test numbers for each cylinder. You can pick up a leak-down tester cheap at Harbor Freight. Follow the directions and post your readings. From there we can get a pretty good idea of the state of your rings. Now one other thing... rings do wear in. Even if say for example the compression rings were installed upside down there is at least some possibility that they might eventually stop smoking. OTOH, my first Buick 215 came out of a pristine Special with 20K on the clock and oily tailpipes, so YMMV. I figured it was built by a hangover on a Monday, got upside down rings, and the owner got tired of the oil smoke. But let's not jump to conclusions just yet. Talk to your builder and see how certain you feel that he didn't screw up (he will say he didn't of course). Even the most experienced builder can make a mistake but the uninformed will do so far more often. Do the test drive. Do the other tests. By then maybe another possibility may have emerged. Jim |
