alcoa7v8
thomas vagasy
(17 posts)
06/11/2013 07:17PM
1980 MGB 4.6 Rover v8
Panasports for mgb
Posted by: alcoa7v8
Date: September 03, 2018 02:58PM
What is the widest 15" panasport and tire combo that can be used on a rubber bumper 1980 B
RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
1979 MGB 4.6L Rover V8
Re: Panasports for mgb
Posted by: RDMG
Date: September 20, 2018 10:34AM
I’d look on mgexp for several threads on this, but I think the safe answer is 15x6 with 195/60r15 tires.
Some MGBs can handle 15x7 wheels, but not all. Apparently the factory was not precise when welding brackets onto the rear axle, and some cars have rear axles that are up to 1/2” off center. In any case, 15x7s require a very specific offset, but I’m not sure what that is. Turning up the rear fender lips may be required.
There’s a guy selling VTO wheels that are a very close match to panasports at a fraction of the price.
Date: September 20, 2018 11:08PM
Wait for Graham to chime in. Pretty sure he fit 205's or maybe 225's on his before he switched to a 4-link rear. He should be able to give you the wheel size including offset or backspace and tire size.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: September 21, 2018 10:16AM
As Rob has mentioned, I have 15x7 Panasports with 22mm offset and currently shod with 205/55R15 Yoko S-Drives. Prior to these I had 225/50R15 Goodrich T/A's.
In a perfect world with the axle centred between the wheel wells, 195's should work with no fender lip mods - anything above (205/215/225) , I'd expect some lip removal/rework....but no rework to the axle bump stop.
If your axle is not centered, then the above does not apply!
On the front, depending on tire size, I'd expect some possible interference with the front sway bar at full lock (I have that condition on mine)
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: September 21, 2018 10:54AM
Hi Graham,
What is your rear axle width out of curiosity?
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: September 21, 2018 12:49PM
Per my old notes: 51-11/16" across the rotors.
IIRC I had Moser essentially duplicate the std MG bolt on axle width.
EDIT: Found some other notes that suggests 51.0" across axle flanges - that implies that rotor hat thickness is 11/32".
Edited 1 time(s). Last edit at 09/21/2018 01:31PM by ex-tyke.
