djw090
David Witham
Warwick UK
(115 posts)
06/12/2008 11:20AM
MGB 1974 and MG ZT 160 turbo 2005
MGB and MGC wheel flanges
Posted by: djw090
Date: April 30, 2009 10:45AM
As far as I am aware the MGC rear axle is of the same design as the later MGB rear axle. (Sailsbury tube). So I expect that MGC flanges can be put on a B so as to enable it to take 5 stud wheels such as the ones on a Jaguar.
I know that the front suspension of an MGC is of a very different design to that on an MGB but are the stub axle assemblies or wheel flanges of a similar design?
Alternativly, does any one know where one might find 5 stud flanges that could be fitted to the front of an MGB.
I am interested in running the Jaguar "kent" style alloys.
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Re: MGB and MGC wheel flanges
Posted by: Bill Young
Date: April 30, 2009 12:05PM
David, if you already have the MGC components then go for it, but if not be aware that most of the MGCs sold in NA came with wire wheels and the bolt on hubs and axles are very hard to find. As I recall the Jaguar wheels share the same lug pattern as the standard Chevrolet pattern. There are a couple of ways to go for the rear, either redrill the existing hubs and brake drums for the correct pattern or install a narrowed Chevy rear axle. The axle from the S10 pickup is popular for this as it is the cleanest housing already designed for leaf springs. With that swap you also get access to many many gear ratios to pick from as well. For the front there are a couple of options. There is a Chevy front hub that can be adapted to the B spindle as we are using on the Roadmaster project or you can go with a custom hub from someone like Classic Conversion Engineering.
Date: April 30, 2009 12:22PM
Bill's advice pretty much mirrors what I was thinking...
However, when I'm logged-on here as "moderator" I have an advantage in that I can usually tell where people are posting from. (ISP addresses appear on my screen, next to where "UserID" is displayed.) Bill mentioned that North American MGC's almost always have wire-wheel axles and that a Chevy S10 axle might be a sensible upgrade, but I'm pretty sure David is in England. I don't know what axle options might make economical sense in that case.
Everyone: please consider taking a moment to update your personal information. Our message board now has 700 active/registered users. BritishV8 is a global community now. You can enter your physical location, what car you own, and an avatar image to display to the left of your messages. Just click on "My Control Center" and then click on "Change My Profile". It's pretty quick and easy!
djw090
David Witham
Warwick UK
(115 posts)
06/12/2008 11:20AM
Posted by: djw090
Date: April 30, 2009 05:35PM
Curtis, I have now updated.
Bill, over here a Chevy is a rebadged Dawoo and they are all front wheel drive shopping baskets. A reasonable number of MGCs came with bolt on wheels. I have not tried to get any flanges and drums though. Redrilling is something I had not thought about. It could be used both front and back I guess. It was seeing the Jaguar Kent alloys on the roadmaster that made be think of fitting them on my B. Plenty of scrap Jaguars here. So I had thought about a narrowed Jaguar IRS back end but that would be a much bigger job.
whisperer
Hal W.
Central Oregon USA
(3 posts)
03/18/2009 11:50PM
1980 MGB 302 SBF
Posted by: whisperer
Date: May 01, 2009 11:33PM
David, I'm fighting the same exact fight. I did re-drill one of the stock rear hubs but am not happy with the way it came out. I am going to do them differently and buy a second one to replace the first one I did, unless of course I can find a set of hubs that somebody else makes. I'm looking at a 5 x 4-1/2 pattern.
My original 1980 hubs are forged with thicker areas around the 4 original bolts on the back side. I'm confident that the thinner areas where 4 of the new 5 bolt pattern go is strong enough for a street car as it's about .375 when spot faced on the back to make a flat stud seat, (the fifth shares an original hole on a 4-1/2" bolt circle). The problem I ran into is that the MGB studs are a tapered seat-type and after cutting the taper then the thickness goes down to about .25". That's fine to roll it around on, and there's lot's of OEM axle flanges that are about the same thickness, but I'm not feeling groovy about it for my V8 car.
I think the answer is to use a flat-seated stud and only spot-face the back flat and to the minimum amount.
Bill, do you have more info on the Chevy front hub conversion? Which application is this from?
MG four six eight
Bill Jacobson
Wa state
(324 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: May 02, 2009 01:05AM
Front MGC hubs are a direct bolt on to the MGB front suspension. You will also need MGC rotors and MGBV8 calipers. The MGC rotor (11" diameter) is machined down to the MGB diameter of 10.75". It's easy to do on a standard brake lathe. MGC rotors are 1/2" thick, same as a MGBV8, which is why V8 calipers are used. This also makes a nice brake upgrade to your MGB! The MGC bolt pattern is 5 4 3/4", which very common and wheel selection easy.
Bad news is MGC bolt on hubs are REALLY hard to find.
Bill
(4513 posts)
Date: May 02, 2009 04:06PM
"...over here a Chevy is a rebadged Dawoo and they are all front wheel drive shopping baskets"
Such sacrilege!
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(108 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: December 24, 2018 02:10PM
Porsche rotors from a 944 is a direct fit to the front axle but then you get stuck with the Porsche bolt pattern. I am working on a solution to have the rear ones fit also to the MGB hub. Front rotors from the 944 are ventilated so very good braking and no fading. I'll try to send a pic in another message.
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(108 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: December 25, 2018 08:01PM
Carl,
Why would you call it a shopping basket. It must be a fast one because it has a 2.2 L 4 cyl engine DOHC made by GMC. My father in law had one and I did all the maintenance on it. Loved to take it out for a quick around the bloc.
Too bad they don't make such a cheap good car anymore.
Werner
(4513 posts)
Date: December 26, 2018 09:46AM
I was quoting David from the UK, above my post, Werner. I do not have any experience with a Daewoo FWD.
twentyover
Greg Fast
Burbs of Detroit
(2 posts)
02/29/2008 06:33PM
1968 MGC GT 2.9 C series
Posted by: twentyover
Date: February 17, 2019 07:26PM
Before I got bolt on hubs for my MGC, I had some unusable spline drive hubs with clapped out splines.
For the rear, I had the splines and the taper machined off, and installed longer wheel studs to use bolt on wheels
Similarly in the front, I had the splines and taper machined off, then added a 1" spacer to the hub. This spacer allowed me to use a 1/2" countersunk screw on the hub side tapped into the hub to retain the wheel, and a 3/8" (IIRC) countersunk screwfron the wheel side of the spacer through the hub and rotor to retain the rotor.
An option if you have some used up hubs, the machine work and all cost less than the bolt on hubs did. Always good to have options.
Edited 1 time(s). Last edit at 02/17/2019 07:51PM by twentyover.
