teejay
terry jones
Raleigh, North Carolina
(8 posts)
12/29/2019 01:44PM
74 MGBGT (now) mildly warmed over B. Coming soon 95 3.4!
choosing the right flywheel
Posted by: teejay
Date: March 25, 2020 10:18PM
Hello all, the 3.4 BGT project is under way, and I am seeking some advice.
I am using a '95 Firebird 3.4, with 94 Camaro T5 and bellhousing, and want to know which
S10 flywheel is the right one to use? Clutch will be stock Camaro (maybe with Ford disc),
probably with Howe HTOB. I have a '95 S10 flywheel now, but from a 2.2 so suspect that is
too small for the 10" Camaro clutch. I am not opposed to buying new or used and resurfacing
and balancing with the clutch.
Thanks for the help and
Cheers!
Terry
(2463 posts)
Re: choosing the right flywheel
Date: March 25, 2020 11:48PM
Terry, you need a S10 2.8 V6 148 tooth internal balance flywheel. Usually you would use the S10 pressure plate too. If you are using the Camaro pressure plate you can use the 3.4 flywheel too. People like the 2.8 bellhousing to mount the T5 straight up instead of tilted. If you use a Ford T5 you need the Turbo 4 clutch disk.
teejay
terry jones
(8 posts)
12/29/2019 01:44PM
Posted by: teejay
Date: March 26, 2020 11:54AM
Thanks, Jim. I am using the Camaro bell housing and modifying the shifter for the tilted condition, since the bell housing came with tranny.
(4514 posts)
Date: March 27, 2020 02:39PM
Didn't come with a "bent" Camaro shifter? ;)
teejay
terry jones
(8 posts)
12/29/2019 01:44PM
Posted by: teejay
Date: March 27, 2020 11:24PM
Hey Carl, I'm working on that....maybe Max can help??
seattlepirate50
Charles Strong
(1 posts)
04/17/2020 09:36PM
Posted by: seattlepirate50
Date: April 17, 2020 09:39PM
I have a 3.4 stock resurfaced flywheel you can have for the postage. I have no idea how much that might be. I had it resurfaced then decided to go with a lightened flywheel from BMC
Chuck
wspohn
bill spohn
(31 posts)
10/23/2007 09:14AM
Posted by: wspohn
Date: June 14, 2020 04:33PM
I use the GM T5 and have no difficulty with the shifter being slightly offset.
[www.rhodo.citymax.com]
