Carb to hood clearance
I have 3 intakes -- each different in height. Of course the one I want to use is the tallest; last choice is the shortest. I don't have an air cleaner yet but have measured from air filter flange on top of carb to the bottom of the hood. How much space do I need for the air cleaner assuming I can use or adjust the base to make it a drop base?
Is 2 1/2" ok? 3"? More? Thanks, Rob |
Re: Carb to hood clearance
Rob, For reference, underhood clearance on my conversion ( using Edelbrock Performer 2121 intake, 600cfm Edelbrock carb and 5/16" phenolic/gasket) using a lump of sealer/plasticene at the location listed below and closing hood.
Air cleaner mounting flange (at front of carb) to hood........2-1/8" I use an older drop base 14" cleaner but it has an intermediate drop of 3/4" vs the typical 1-1/4" available today. Hood clearance at the front of the installed cleaner lid is about 3/16". BTW - the Indy clock is ticking.......... |
After putting up with my non-LBC friends telling me it can’t be done and then seeing the look on their faces when I showed them pictures to prove that we at the shop did it, I’ve encluded a couple of pictures and a relavent question. I’ll be batteling the same issue shortly but think I’ll go with the RV8 hood because of the distributor, still I feel the need to do something a little different with the aircleaner. My ex-son-in-law was tinkering with the idea of putting a 240SX motor in it and cut the heater shelf out but by the pictures you can see I clearly had a different direction in mind. As we are a fabrication shop I was thinking of fabing a top for the carb, using a K&N filter, and the heater blower motor intake hole for cold air intake. I know there would be issues with water and such but thought I’d put in my two cents worth and see what you guys think. “P”
Graham, thanks for the info -- and you don't need to remind me about the clock -- it's stressing me enough already. I measured a little over 2 1/2" clearance from the air cleaner mounting flange to the hood using a performer RPM air gap type manifold so I guess that's the one I'll use.
Paul, check out Curtis' car in the gallery. He used the fresh air intake like you're thinking. |
That is what I was thinking, Curtis just beat me to it. Curtis, do you ever drive it in the rain, and if so do you have any problems with it? "P"
No problems. Last June, for example, I got rained/poured/dumped on in every single state from Colorado to North Carolina (coming East for the BritishV8 meet) and the induction system didn't give any problem at all.
I have a screen at the top to keep out debris, and the rubber bulb at the bottom has been removed. The system does suck a little warm air out of the tranny tunnel, but it can evacuate a lot of water with no problem. Possibly the biggest downsides of this approach for most people would be (a) giving up some cabin ventilation, and (b) you'll inevitably end up with more engine noise transferring into the cabin. re: cold air induction / cowl induction efficacy, some test results are recorded here: [www.britishv8.org] |
Rob, A 14" drop base Corvette type air cleaner with 2" K&N element should fit. Did you cut the reinforcement in the middle of the hood?
Paul, forget about the rain, it isn't a concern at all. I drove my blown roadster in all kinds of weather and there's a lot of air in between those rain drops! If that Enderlie scoop wasn't going to pick up too much water I can't think of anything that would.
JB |
Jim, no, I didn't cut the center support bar. I'm pretty sure Graham's is still in tact so unless I have that wrong, his measurement of 2 1/8" carb flange to hod at the front should work for me too.
Actually my problem isn’t the air cleaner as much as the distributor. I’ll have to give it some thought. "P"
Quote: My air cleaner lid falls aft of the hood "hat shaped" crossmember...so, all is still in place! For Paul's reference, my std Ford distributor has about 7/8" clearance to the hood crossmember. |
Graham, in the pictures you’ll notice the distributor is removed. The picture was taken between it’s removal and taping up the hole. It is a ProComp 7002 Electronic distributor and the hood hits it. By most pictures I see in the “How It Was Done” section the harmonic balancer is in the same position above the steering rack and the pan has the same clearance so I’m pretty sure the motor is in the right place. There are a number of things I don’t like about the distributor including limited rotation for timing due to an electronic unit on the side, so there is thought of changing it. I like the RV8 hood but would use the stock one if possible. "P"
Paul, distributor was purchased at a parts swap meet and has ID # D2AF 12127. This is a Ford coded product identifying the year and application. You could google info on this code but this design distributor was used over many years in Mustangs, Galaxies, trucks, etc with the 302 engine.
Make sure that the drive gear is compatible with your cam - I am running a Ford Racing "B303" cam which requires a steel drive gear. Phil G, thanks for the compliment. |
jblanchard@hcpg.net Jeb Blanchard Collierville, TN (53 posts) Registered: 12/07/2007 01:01PM Main British Car: 1961 MGA Chevy 4.3 Vortec V-6 |
