papaluccio
Ross Dunlop
(6 posts)
06/05/2016 02:19AM
Range Rover 4.6 into MGB problem
Posted by: papaluccio
Date: June 05, 2016 02:28AM
First time posting here. Would really appreciate any experience or ideas anyone might have on this:
Some years ago I put a 3.5 from a TR8 into my MGB. I'm now swapping the 3.5 for a 4.6 from a 1999 Range Rover HSE. I've had some difficulties in/around the timing cover. Solved a few problems, but still have one or two, most notably, I've got a:
Main bearing cap bolt -- oil pump problem. The bolt sticks out of the block and interferes. Has anyone who's done a 4.6 conversion come across this? Any ideas how to get round it?
(4511 posts)
Re: Range Rover 4.6 into MGB problem
Date: June 05, 2016 10:53AM
A pic would be helpful.
mstemp
Mike Stemp
Calgary, Canada
(222 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: June 05, 2016 03:27PM
Ross,
Are you using the 4.6l timing cover and oil pump?
Most of us have changed to the Buick style setup.
On the rear where the starter goes I did have an issue with one of the cross bolts. Needed to use the Allen head type and counter sink to hole in the block. But no issue at the front. Here is a photo of mine.
Edited 3 time(s). Last edit at 06/06/2016 12:25AM by mstemp.
(4511 posts)
Date: June 05, 2016 05:31PM
Go here to resize it.
[www.picresize.com]
Change it to 600x???. Just put in the first value & let the program pick the other. That will retain the same aspect ratio.
papaluccio
Ross Dunlop
(6 posts)
06/05/2016 02:19AM
Date: June 09, 2016 05:04PM
Thanks so much, Mike. No, the timing cover I've used I sourced from a wreckers, I think it's off a Discovery. Perhaps the Buick route will get this all solved. Where did you get Buick parts? What year/model of Buick am I looking for if I start hunting around for a Buick style set up and what all do I need? Timing cover, oil pump, … what else?
Thanks again for the help so far!
papaluccio
Ross Dunlop
(6 posts)
06/05/2016 02:19AM
Date: June 09, 2016 05:45PM
Here's a picture of the problem, Carl...
mstemp
Mike Stemp
Calgary, Canada
(222 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: June 09, 2016 06:04PM
Ross,
Looks like a simple matter of changing the oil filter remote take off plate. You already have a Rover or Buick timing cover and oil pump, its that remote filter plate that is causing the issue. D&D used to have an oil pump cover that allowed you to swivel the filter. It was two parts, the Buick "Metric" stamped oil filter flange and then a Caddy swivel I think. Worked very well in the MGB. Its what I have as do many others.
Or if you must have a remote filter use a standard TransDapt version.
Or remove the offending cross-bolt, drill/counter sink the hole and use an allen head bolt. The other side of the motor should have one installed at the rear already. You may also need to do similar on the RHS rear depending on what starter you use.
Edited 3 time(s). Last edit at 06/09/2016 06:20PM by mstemp.
papaluccio
Ross Dunlop
(6 posts)
06/05/2016 02:19AM
Date: June 10, 2016 12:19PM
Fantastic, Mike, thank you so much. Will pursue all those options. Cheers!!
ultrabluea9x
glenn valentine
(5 posts)
08/26/2021 03:27AM
Posted by: ultrabluea9x
Date: August 28, 2021 02:47AM
do you still have the old oilpump take of?
spridget
bill green
Maine
(68 posts)
03/22/2008 01:29PM
3 1980 TR8, 1 TR7 2 Bugeye Sprite 1 MG midget TR8 3.5 and 5.0, Sprite 1098 and ?
Posted by: spridget
Date: August 28, 2021 07:08AM
Why don't you use the TR8 timing cover?
jannhall
Joyce Hall
(12 posts)
09/30/2021 03:34AM
2007 Aston Martin Vantage V8 4.3L
Posted by: jannhall
Date: November 08, 2021 06:36PM
How did it go? Which product did you end up buying?
