Goto Page: PreviousFirst...124125126127128129130131132133134Next
Current Page: 130 of 134
(6469 posts)
Re: MGB Roadmaster
Date: February 23, 2018 02:57AM
I think I might know what happened with the plugs. Since we were running low compression and a cam that is warmer than stock the DCR was probably down some, plus other factors made the 5 heat range plugs a bit cold. I seem to recall maybe we had some early issues with plug fouling and had decided to go one step hotter. So my guess is whoever changed the plugs did that, and not knowing about TA heads just bought plugs for a BBB. Then went the extra mile and got platinum. Pretty logical you would think. Anyway I have a set on the way and they aren't platinum but the Buick guys agree that they are about the best choice.
Couldn't see any bubbling in the surge tank today but the level is down a bit. I'll get some distilled water tomorrow and add a bit of coolant and re-check. So far, so good. Another week or so and I start trying to schedule another work weekend.
(6469 posts)
Re: MGB Roadmaster
Date: March 03, 2018 01:49PM
The plugs came in finally. I had to go buy a special small diameter spark plug thread chaser and I have to chase all of the threads because they have a buildup at the bottom and the plugs won't go all the way in.
Thanks Obama.
I'm halfway done. the easy half.
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
74 MGB-GT 3.4 V-6 crate, 5 spd
Re: MGB Roadmaster
Posted by: lawnvett
Date: March 04, 2018 02:33PM
guess this will fix the spark plug auto removal events ha ha
Or maybe it's a hex on ME. I drive RM and spark plugs like to remove themselves from the head!
sure is LOUD when they pop out while motoring just ask Kelly.
(6469 posts)
Re: MGB Roadmaster
Date: March 04, 2018 07:31PM
Yeah, I think having the right seat will make that problem go away. Got the rest of the plugs changed and went on a short drive. Seemed fine, I couldn't tell if it ran any better. Gas mileage could go up a little. Need to drive it about 30 more miles then put it on the lift and swap out the fuel tank sender. Easy job once the gas is used up.
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
Re: MGB Roadmaster
Posted by: lawnvett
Date: March 12, 2018 10:03PM
It's always fun using up gain that car, I remember filling it three time in WVA last summer.
Havefun.
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
Re: MGB Roadmaster
Posted by: lawnvett
Date: April 03, 2018 10:08PM
HI JIM
HAVE YOU BEEN ABLE TO ENJOY ANY SPRING DRIVES IN RM
(6469 posts)
Re: MGB Roadmaster
Date: April 04, 2018 11:46AM
Not really any drives, though I have taken it on a few errands. Ran out a tank of gas and swapped out the fuel tank sender, the old one had the float filled up with gas. New one in there now.
It's running probably the best it ever has. No more work has been done on the A/C. I pulled a vacuum on it last time we worked on it but haven't checked if it's holding yet. Have given some thought to how to make the control panel, that should be simple enough. Dan tells me he won't be free for another work session until after his daughter's wedding the 9th of June. We need to install the wiring and whatever ductwork we are going to do and then charge the system.
It still attracts attention where ever it goes.
Waiting on dry weather now, I suppose we are *finally* done with winter.
(4512 posts)
Re: MGB Roadmaster
Date: April 05, 2018 10:25AM
Maybe after this weekend. You be looking at snow Saturday.
(6469 posts)
Re: MGB Roadmaster
Date: June 13, 2018 06:04PM
Good News everyone!
The MG-Roadmaster now has a working air conditioner system. Steve and I went for about a 1/2hr+ test drive this morning and it blows out a good quantity of nice cold air. After awhile it began to ice up so we cracked the heater valve to de-ice the evaporator and restored operation. It left a large puddle on the floor when we parked it from condensate, it's been very humid here today (85%). It could use one more eyeball vent for the driver's side, right now both tubes just dump on your right leg, but I figure anyone can add that later. We do have an eyeball vent on the passenger's side, which can be directed towards the driver.
Do we have any plans to get it to Dayton?
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Re: MGB Roadmaster
Posted by: mowog1
Date: July 19, 2018 09:33PM
Follow-up from the above post.
The Roadmaster made it to Dayton...shout out to our "Mule", PJ Lenihan for driving to Jim's house to pick it up.
I brought the car home with me (PJ caught a ride with one of the Blackwoods to retrieve his car in Florence).
The Roadmaster drove flawlessly throughout the 220 mile trek to Illinois.
The EPS is a definite plus.
The a/c is nice....but I agree with PJ in that we need a little more ducting to the driver's side of the cockpit.
I got about 18 mpg (based on the car's odometer, which I have not verified against a GPS).
Oil pressure, operating temp, and charging system was all good.
There is a bit of a shimmy in the wheel.
I will be campaigning the car at local Cars & Coffee, street rod shows, and will be driving it to East Peoria, IL to a........Fiero National....to let them see where all of their seats are going. If I still have the car in SEeptember, I would consider taking it up to Chicago to the all-Brit show and down to St.Louis to their all-Brit show.
Stay tuned.
Edited 3 time(s). Last edit at 07/20/2018 02:06PM by mowog1.
(6469 posts)
Re: MGB Roadmaster
Date: July 20, 2018 08:57AM
Rick, also it might be worth taking in the GS Nationals in Bowling Green, KY this fall. It was quite a lot of fun when Matt and I took it down there, and they really did like it:
[www.gsnationals.com]
I'm not saying take it on the dragstrip, but if you wanted to they'd be fine with it.
(4512 posts)
Re: MGB Roadmaster
Date: July 20, 2018 10:38AM
Don't take it down the dragstrip. The timeslip will be embarrassingly slooow for a car that looks like that. NO ONE will be impressed.
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
Re: MGB Roadmaster
Posted by: mowog1
Date: July 21, 2018 01:15PM
Took the Roadmaster to a local Cars & Coffee this morning....low turnout due to intermittent sprinkles....but still a good time.
The Roadmaster drew a crowd most of the morning. Also had several children sit behind the wheel.
(4512 posts)
Re: MGB Roadmaster
Date: July 21, 2018 05:35PM
Pics?
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
Re: MGB Roadmaster
Posted by: mowog1
Date: July 21, 2018 10:40PM
Look on my FB page. It's a pain in the arse to resize every pic prior to posting here.
I didn't take too many.
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
Re: MGB Roadmaster
Posted by: mowog1
Date: August 13, 2018 10:11PM
I put about 200 miles on the Roadmaster on Saturday.
Took it to Peoria, IL to.........a National Fiero Meet.
Got a lot of looks and answered a lot of questions.
Plan on taking it to Cars & Coffee in Champaign, IL on Saturday morning and to "Motor Muster" at Frasca Field in Urbana, IL later Saturday morning/afternoon.
The car is running well....and getting about 17mpg combined mileage.
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
Re: MGB Roadmaster
Posted by: lawnvett
Date: November 17, 2018 09:22PM
I found the missing
a/c eyeball outlet vents and some left over hose, to do a little additional air flow to the drivers face for RM
It's all boxed up and ready to drop off for delivery to Rick
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
Re: MGB Roadmaster
Posted by: lawnvett
Date: January 03, 2019 11:28AM
Are there any plans to bring RM yo MG 2019?
I'm unable to help with this as I'll be leading a group from NC along with Dick Lunney.
We'll do another one of our leisurely sightseeing road trips to and from Traverse City MI
Re: MGB Roadmaster
Date: January 03, 2019 08:37PM
Where is MG 2019?
(4512 posts)
Re: MGB Roadmaster
Date: January 04, 2019 04:39PM
Traverse City, MI
[mg2019.regfox.com]
