Re: MGB Roadmaster
Carl, et al:
Yeah, I read through the logbook and there wasn't much recorded re: pinging. Since that time, however, I believe PJ changed a fuel pump. And we also changed carb. (Was it a 750 before and is now the 850?) It has also been dynoed since then, and they made some changes (timing, I believe, is what was reported). I does seem, however, from what Steve reported and I experienced, that the pinging might be a "new" thing. (Wasn't there a spark retard box during the Power Tour that was ultimately disconnected?) Fishing for clues.... M |
Re: MGB Roadmaster
I haven't really noticed pinging.... I drove it Saturday to our club picnic, but just cruising really.
Re: MGB Roadmaster
Carb is a 750 from summit.
No electronics has been disconnected. If there was a retard box, there still is. I did not notice ping while I had it. If it runs on when shutting down, it has a clutch, kill it. High test will take care of most of that. If it ping, retard the timing some. steve |
Re: MGB Roadmaster
It didn't ping when I had it and that was after both the synopsis timing changes and the power tour. I did run it on premium gas - 93 octane around here but also up to 10% ethanol. Timing box is a timing control box - designed to manage timing with distributor advance locked out. I still don't understand why we have it and a distributor with advance. If pinging is new and isn't gas related (octane, pump, etc.) maybe the knobs on the timing box got inadvertently adjusted. It's mounted in the cabin above the passenger foot well.
lawnvett PJ Lenihan Winston-Salem, NC (477 posts) Registered: 04/29/2009 11:37AM Main British Car: 74 MGB-GT 3.4 V-6 crate, 5 spd |
Re: MGB Roadmaster
"I believe PJ changed a fuel pump." said Max,
Yes new fuel pump was installed Aug. 2012 . . . and that was shortly after running out of gas, about ten miles after gassing up the fuel pump failed maybe a bit of grit from the bottom, I think we also changed the fuel filter if I remember correctly. . . then came final breakdown, of the TX to IL trip resulting in Riki's expensive speeding ticket.. I didn't hear the "pinging" thought I must be going tone deaf or possibly had the volume too high while listening to the road trip playlist on the iPhone connected to the RM sound system. yeah baby let those tunes rip Edited 1 time(s). Last edit at 06/04/2013 05:10AM by lawnvett. |
Re: MGB Roadmaster
I think the stumble is the biggest issue with how the engine is running now, and you can avoid that if you don't hammer the gas pedal. Funny watching the tachometer spin round and round, back and forth, etc. like a compass on a cartoon. Maybe Bill G. can fix that in Omaha.
Re: MGB Roadmaster
The Roadmaster is now residing in my garage in Saint Joseph IL
I will be checking with Parkland College regarding paint for the new bonnet that was donated by Dave Craddock of Preform Resources. WIll attempt to get paint codes from Terry Schuelte. |
Re: MGB Roadmaster
Back from the car show in Savoy (IL). Sunny & hot at first....then the skies openned up and produced about 2-1/2" of rain in a two hour time frame. The car gathered a LOT of interest and comments....all positive.
There were at least three Buicks with 455's...and the Roadmaster got their attention almost immediately. Here's a few photos from today...... |
Re: MGB Roadmaster
did you post about this show anywhere previously?
Re: MGB Roadmaster
I did not know about this show until Friday evening.
I was able to make it because Savoy is 15 minutes from Saint Joseph. I found out about a show in SW Michigan yesterday as well...that had I known about it, would have been there today as the MGB/GT was the featured car. Other plans had already been made by that time. |
Re: MGB Roadmaster
I think one of the controls might be stripped.
Take the knob off and try turning it with needle nose . Defrost did not work for me when I drove it to Max's for the rearend change Worked other times. Steve |
Re: MGB Roadmaster
I'm sure glad to see you're having fun this time around Rick! (Now just keep a close eye on that radar detector ;-) Personally, I think we should be thinking about installing A/C and cruise control. It would make the car SO much better.
Have you looked at the new steering column yet? Jim |
Re: MGB Roadmaster
Re: MGB Roadmaster
Rick, when I gave Dave the dimensions I recommended that the passenger's side be made 1/2" wider and the rest looked OK to me. It rubs a little on the left. You have the car, you make the call.
