Bobbydm Rob Moore Surrey, UK (11 posts) Registered: 01/29/2010 09:41AM Main British Car: 1972 MGB v8 (1979 shell) 3500cc |
RV8 Alternator
Dear Experts....
Guys I have a 1978 wiring loom in my Uk car and have upgraded to an RV8 alternator. I have to be honest and say electrics are my weakness, i have read lots of guides and made sure I have the correct gauge wiring for the extra amps but have no idea which wire goes where on the alternator. if anyone has the RV8 alternator on their car can you please advise me which connection goes where!!! Please.... The connections are 3 studs (all different sizes) and 3 L shape plugs. I don't want to start guessing and starts sparks flying! Thanks for your help!!! |
Simon Austin Simon Austin Surrey, British Columbia (72 posts) Registered: 10/23/2007 01:44AM Main British Car: 1977 MGB V8 / 1994 MG RV8 Rover 3.5 / Rover 3.9 |
Re: RV8 Alternator
Re: RV8 Alternator
Simon thats great thanks. Looks like mine isn't an RV8 alternator even though a specialist sold it to me as one.
The L-shape fittings look like the ones that come from the black block marked 02-94. Mine doesnt have these blocks at all! I will post some photos as well but for now does yours have any letters next to the terminals. For example just the letter B or anything like that. Thanks again! |
Re: RV8 Alternator
Sorry it took so long to get back to you, Rob. I don't venture on here very often. I'll look in the morning at the terminals and see what's on there.
I'll post some photos of the alternator wiring on my Rover 3.5-powered MGB as well. Maybe its alternator is similar to yours. For now, here's a shot of it during the build. |
Re: RV8 Alternator
Simon,
That would be great. The alternator on your B v8 looks exactly like mine! In fact the car looks the same colour! Looking forward to hearing from you! |
Re: RV8 Alternator
I should also mention on further inspection mine does have the black blocks that are the same as your RV8 alternator.
Any markings from yours will be sure to help. |
Re: RV8 Alternator
Hmm....interesting. Looks like a bit of a hybrid you have there. Just so I have this correct; your alternator looks like my grey V8's one but has the black blocks of the RV8?
FWIW, the V8's alternator plugs directly into the stock '74 wiring harness I used to wire the car. That may or may not help with identifying it. I will get you some photos asap. I'll also look in the RV8's shop manual in an attempt to sort out its wiring and the plugs. Cheers Simon |
Re: RV8 Alternator
It is clearly from the RV8 now that I have it off the car. i just want to confirm the locations of each wire if thats possible.
DiDueColpi Fred Key Canada (48 posts) Registered: 05/14/2010 03:06AM Main British Car: Do you mean one that runs? Engine by lotus, about 2 foot square. |
Re: RV8 Alternator
Hey Rob,
The black blocks on the alternator are noise supressors for your radio etc. The loose one in the photo should go to the W terminal. This terminal won't be used on your car. It is a phase tap and is usually used as a tachometer feed for diesel applications. The B+ goes to the battery or starter terminal through the heavy brown wire. I would not use the one in the factory harness. Upgrade it to at least a 8 guage wire to be safe. The D+ goes to the brown yellow wire. This wire is for voltage sensing and turns the idiot light on in the dash. That should do it. Cheers Fred |
Re: RV8 Alternator
Fred....you are my hero! I have already upgarded the cable thanks to the Roger Williams book!
I will do this tomorrow and then its off for a UK MOT!!! Just a pic of the nearly finished car! ![]() |
Re: RV8 Alternator
Nice car Rob. What are the side vents from?
Re: RV8 Alternator
Very well spotted. Its the only real modification that stands out from being original! They are from a works Healey 3000. The inner wings are also vented to allow air flow for cooling and to prevent the nose lifting at speed!
Re: RV8 Alternator
Not to everyones taste and a bit overkill but I have always wanted a works Healey and this as close as I can get for now!
apexhunter Alan Van Reed Boston, Massachusetts (6 posts) Registered: 07/29/2010 01:30PM Main British Car: 1971 MGB Rover 4.2 |
Re: RV8 Alternator
Bobbydm,
You must be stoked ...... almost complete ..... great build quality ....... I also like the vents ......... We all have AH cravings ... and very difficult to find a sound one to restore any more ....ones that are done have decent are fetching big money ...are the wheels panasport? what size? Alan Boston |
