accobraman50 Arthur Mitchell Chicago (43 posts) Registered: 01/27/2008 08:14PM Main British Car: 1965 Butler Racing AC Cobra replica 350 SBC |
Steering column bearing modifications & Turn- Signal switch
I had rebuilt my 1971 (Edit: I think my column is from 1962-1967) steering column with new upper split bush and lower felt bush. I have not driven the car since the rebuild. Yesterday I pulled the column assembly out of the car and the found the upper bush had been chewed up by the turn signal cancellation pin. I'm thinking I need to modify this. Looking to others that may have encountered similar problems. Or has anyone made modifications as follows:
I plan to machine (turn) the steering shaft its intire length to 7/8" actually .872" diameter as it is worn a little. Then I will machine off the rolled edge at the bottom of the column tube. Machine two collared bushes from MDS-Nylon. Insert one bush in each end of the tube and slide the shaft in. My turn signal switch is also in need of repair. It's a simple fix, but if I can buy a new one I would. Anyone know of a source? I've checked Moss and a couple of other suppliers but no luck. Ebay has the later model but not mine. Look forward to feed-back. Thanks, Arthur Edited 1 time(s). Last edit at 02/29/2008 12:52AM by accobraman50. |
