MGV Luis Velasco Peru, IN (9 posts) Registered: 04/04/2010 10:44PM Main British Car: MGB 1979 3.4L Chevrolet, T-5 BW Transmision |
Radiator problems.
I order a new radiator is a little bit taller than the original.
The bottom exit is under the anti-sway bar. Do this will be a problem? Looks like is to low compare with the water pump (3.4L chevy). Can I just use a radiator from a 1976 MGB? What is the inlet & outlet size for this radiator. The 3.4L that I have the inlet/outlet are 1 1/4 inches. What will happen if I remove the anti-sway bar? Thanks Edited 1 time(s). Last edit at 09/18/2010 11:18AM by MGV. |
