pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
1972 MGB-GT 1979 Ford 302
I'm Always Full of Questions
Posted by: pspeaks
Date: October 21, 2010 12:00PM
I have two questions:
1: I was looking at Shaun Holmes beautiful MGC-GT and as I have a little distributor clearance issue was wandering if a C hood would fit my 72 B, given that I could even find one of course.
2: The piece between the square under dash cross brace, which I need to modify for the ac/heat/def unit anyway, and the transmission tunnel, that the back of the radio goes through, I’m sure there is some structural reason for it being there, but what would happen if it were removed. I have a wood shop and have been thinking of making a flat wood dash like earlier models and would look much better with that piece removed. Maybe veneered bubinga or santos mahogany.
"P"
MGB SS
Joe Schafer
Central Michigan
(150 posts)
10/23/2007 06:46AM
1971 Mgb 1991 5.0 Ford
Re: I'm Always Full of Questions
Posted by: MGB SS
Date: October 21, 2010 08:27PM
Paul
Do you have the shorter Ford Distributor, not sure what ignition-Intake you are running but there are shorter ones in some Models
As to the hood I believe that there are after market "C" hoods out there but I think the bump is to far forward for the Dizzy clearance
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
Posted by: pspeaks
Date: October 21, 2010 11:36PM
I have a ProComp 7002 distributor which sets about ever with the hood cross brace and a Ford Typhoon Aluminum Hi-Rise manifold 910-11275-PLN from Speedway. I'll give the hood a little more thought and check out the aftermarket C hoods. Thanks a lot for the info Joe, "P"
Date: October 22, 2010 08:38AM
check Graham's write up. Don't recall what year range but he's using a a '70's ford oem one that is pretty short. MSD also has a short billet distributor but it's more expensive.
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
Posted by: pspeaks
Date: October 22, 2010 09:02AM
I saw Graham's write up and have been looking for an earily Ford distributor. Besides being tall I have other issues with the 7002 but was trying to find a way to use a distributor I have already paid for. My motor is a 79 and had the perfect distributor coming out of the donor car but it was in such bad shape I tossed it; as it turns out, probably a bad idea! "P"
B-Fast B-Strong
William Smith
(144 posts)
10/17/2009 11:28PM
Bugeye Bodied Spriget
Posted by: B-Fast B-Strong
Date: October 22, 2010 07:55PM
Oh ! Really ! I'm always full of something else !
Paul,
Why don't you cut the top of the distributor off and let it only drive the oil pump?
William
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
Posted by: pspeaks
Date: October 23, 2010 10:01AM
I hadn't thought of that, it's a pretty good idea :-) "P"
