Rover Ignition
I have a Rover 3.5 with the original distributor and Pertronix module. I think that the HEI distriutor from a 350 Buick will fit but I'm not sure about hood clearance. I don't have a distributor at hand to measure and try. Has anyone out there tried this? Thanks!
Bugeyev8 Brian Marshall San Leandro CA (32 posts) Registered: 12/16/2008 08:53PM Main British Car: 1960 Bugeye, 1974 MGB,Triumph TR8 1.2 115 Hp 1275 in the Bugeye, Nissan Ka24DE in MG |
Re: Rover Ignition
the Buick 350 dist will fit, you will need to replace the intake bolt with a button head allen bolt
jimbb88 Jim Stuart Maryland, USA (47 posts) Registered: 10/23/2007 07:43PM Main British Car: 1966 MGB V8 conversion Rover 4.0 fuel injected |
Re: Rover Ignition
The HEI dizzy will not clear the hood unless the engine is mounted very low and further back than normal.
I ran one for a while by spacing up the hood- looked terrible. Run the Pertronix and a MSD if you think you need more spark. |
