jbarila
John Barilaro
Red Sox Nation!
(60 posts)
11/02/2007 08:29AM
1977 MGB Ford 302/5L
Fuel System Opinions.
Posted by: jbarila
Date: March 12, 2008 08:09AM
What is the general consensus on upgraded fuel systems. Will the stock MG fuel tank pickup handle a V8 upgrade? A 3/8" fuel line is close to the stock size. What have V8ers found?
I think a mild carburated V8 will not be a worry but high horse power FI's might get starved.
Re: Fuel System Opinions.
Date: March 12, 2008 12:35PM
I'll be interested to see what others say. I talked with a couple of folks with Ford 302's & indication I got was stock pickup allowed plenty of flow.
BMC
Brian Mc Cullough
Forest Lake, Minnesota, USA
(383 posts)
10/30/2007 02:27AM
Posted by: BMC
Date: March 12, 2008 02:57PM
Fuel injection: 3/8 line to system, 5/16" line return- constant flow.
Most carbs on cars under a given BHP, Lets say under 300(?): Dead headed fuel flowing in one direction, never a drop in pressure Should be able to use a 5/16" feed line.
Correct me if I am wrong, but quite a few high BHP cars with 3.8 feed line to a FI motor run pretty good. These are minimums. Also, if you go with a 3/8" line to the front, the tank line is a 5/16" so its a bit of a bottle neck, but again, i dont think you need to worry. We have pulled FI motors out of this without issue due to size.
-BMC.
scot abbott
scot abbott
(26 posts)
01/30/2008 06:03PM
Posted by: scot abbott
Date: March 25, 2008 12:12AM
According to Poisueille's equasion, flow resistance at constant pressure goes up by the FOURTH POWER of the tubing radius. A 3/8 diameter tube has 1/2 the flow resistance per foot that 5/16 inch tube has. Thus it is clear that tubing diameter is much more important than length.
If you have any question about the fuel supply capability, simply measure it. One smart measurement is worth far more than a bunch of dumb conjecture.
kstevusa
kelly stevenson
Southern Middle Tennessee
(985 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: March 27, 2008 07:29PM
just cked the web-site Hardcore 5.0 and they have fuel pump calcuator using the flywheel HP. accordingly, a 315 FWHP car (my is in this range (266RWHP), it take 25.4 gal/hour WOT. i have both 5/16" pressure and return with no problem. the system is Ford EFI with a Kirban Adj. pres. reg @39 PSI. my pump will a GM Module from a 99 Malibu with a capacity of 30 gph. it can be upgraded to larger pump if needed. the new system is almost ready to fire up. Brian, did you complete you GM module system?
BMC
Brian Mc Cullough
(383 posts)
10/30/2007 02:27AM
Posted by: BMC
Date: April 11, 2008 12:21PM
Kelly, are you asking me? If so I am not sure exactly what your asking...
-BMC.
