barrysmgb
barry strugnell
(26 posts)
12/24/2010 12:57PM
fabricating rear trans mount t5
Posted by: barrysmgb
Date: December 25, 2010 07:37PM
302/t5 tranny mount want to bolt in best to drill thru frame into interior with gr 8 bolts or angle bracket and bolt hort thru frame rail parallel to floor saw one bolt vert in pics here but could not see if they went thru floor thanks barry
Re: fabricating rear trans mount t5
Date: December 26, 2010 04:26PM
best to make the tranny mount use the existing holes/captive nuts in the frame rails.
mgbreis
Ryan Reis
Beatrice, NE
(203 posts)
07/16/2008 11:07AM
Posted by: mgbreis
Date: December 28, 2010 08:05PM
No need to reinvent the wheel, the stock crossmember works fine. I cut out the center section of the mount with a cut off wheel and welded in a 3/8" plate that bolts to the transmission. I snapped a couple pics to give you the idea (hard to take pics of something 6" off the ground. Ignore the bolts, they're too long and just temporary. Or maybe permanent the way my project has ground to a halt. I should mention that my mount incorporates a urethane mount for a fox body mustang.
http://i29.photobucket.com/albums/c298/mgbreis/IMG_0107.jpg
http://i29.photobucket.com/albums/c298/mgbreis/IMG_0106.jpg
Edited 1 time(s). Last edit at 12/28/2010 08:07PM by mgbreis.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: December 28, 2010 08:48PM
Ryan's approach pretty well mirrors mine. There's a set of 3 tapped holes in each chassis member - depending on your fore/aft engine location, you may have to use the rear 2 and add another couple of matching holes to the crossmember.
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
1972 MGB-GT 1979 Ford 302
Posted by: pspeaks
Date: December 28, 2010 11:15PM
Barry, I've attached a picture of my trans mount. Your looking at the bottom of it but I think you can get the idea. By all means use the existing holes and nut plates.
