undertowrocks David Haywood Madoc, Ontario (24 posts) Registered: 10/05/2010 08:29PM Main British Car: 1962 MGA Coupe Buick 4.1 V-6 |
MGA rotor 4 lug to 5
Is there an adapter plate available to convert the 4 lug MGA rotor to a 5 lug GM bolt pattern, I have a GM rear going in the car and wpuld like to purchase matching rims.
Re: MGA rotor 4 lug to 5
MGB spindles, and check out the other 5 lug threads. 98-2002 LS Camaro slip on rotors and calipers with custom brackets on 68-72 Chevelle/Monte Carlo hub/rotor with rotor cut off,inner race hole bored 1/4",inside end cut off 1/4" (or 68-72 Chevelle/Monte Carlo drum hub) ,bored for MGB seal. Or CCE Wilwood hub and rotor kit.
Edited 1 time(s). Last edit at 02/17/2011 09:55PM by mgb260. |
