MARVIN, CT Marvin Stuart Preston, CT (14 posts) Registered: 02/10/2011 11:38AM Main British Car: '52 MGTD '37 Ford V8-60 |
T5 transmission mount
I'm nearing completion of putting a Mustang t5 in my TD, behind the Ford 60hp. The t5 mount is at least twice as tall as I can use. Any recommendations for a mount about an inch or so tall. Thanks, Marvin
Re: T5 transmission mount
Donut? Is that what you'd call this 2-piece style, like I used for both engine and transmission?
You should be able to find them from all sorts of industrial supply outfits... McMaster-Carr, etc. |
Anchor 2268 - T5 mount - used in early GM and Ford products
I should add that O'Reillys have them for $4.99 [www.oreillyauto.com] Edited 1 time(s). Last edit at 04/06/2011 12:32PM by ex-tyke. |
Marvin,Just curious,did you use the S-10 tailshaft with the Mustang T5? Commonly done in street rod flathead T5 swaps.
Thanks, Marvin! You never know,maybe I'll pick up a TD someday. I know a guy that goes to Brazil every so often. I asked him if he could round up some Ardun style Simca Hemi heads to fit the flathead 60. There are a couple running motors on U Tube. You should be able to bend the shifter in a large vice,may need to heat it.
Doesn't the shifter lever just bolt to a stub on the shifter itself? If so, it might be easier to do what I did -- I welded a bolt to the top of a piece of 1" square tube -- drilled holes through. It slides over the shifter stub & bolts on. If I remember right the stub was a little smaller so I used some 16 or 18ga stock to make shims that I tacked inside the tube. My shifter is a Steeda but I think that part of the design is the same as stock mustang shifter. Was quick & easy & you can make the shifter any lenght you want that way too.
It's a stock TD axle with MGB 3.9 gears. Marvin
deltadave dave plumley unionville TN (69 posts) Registered: 10/24/2010 08:21PM Main British Car: 1953 MG TD Chevy 350 |
I bent the T5 Camaro shifter in my TD, but it took some heat to do it. Glad to see you got the system worked out. I'm painting the TDs wheels and will post the finished pics soon.
J Man jason adkins NW OH (202 posts) Registered: 01/21/2009 08:49PM Main British Car: '61 Morris Minor panel, '70 MGB GT, '74 MGB GT MGB 1.8, unsure yet on the GTs |
Lokar makes a aftermarket shifter for the T5. It would give you a couple other options and they will be better looking.
Paul, I don't have a metric gage, but the bolt head uses a 10mm socket and the treads are 20tpi. Marvin
Thanks Marvin, I just made a run to the hanger where the car is and checked it. I don't know if they're all alike but mine is M8X1.25.
"P" |
