Re: Tube shock question
I could dig up the old file and make more but I would have to ask
what year is your car How is your sway bar mounted. I had a couple people look at doing it and their sway bar was mounted different then mine and was in the way. I see why you are confused. I just read my page and it does say I used the 125. I need to go back and see what I did. It's been a while. I thought I switched back tot he lighter one but that's not what that says. |
ex-tyke Graham Creswick Chatham, Ontario, Canada (679 posts) Registered: 10/25/2007 11:17AM Main British Car: 1976 MGB Ford 302 |
A typical rear coil over spring rate for a MGB would be in 180 - 200 lb/in range.....GT's might go to 220lb/in.
DC Townsend David Townsend Vermont (366 posts) Registered: 11/21/2007 12:22PM Main British Car: '78 B (almost done) 30-over SBF, dry sump |
If it would make it more worth your while, I'd take a set of those brackets as well. Great idea.
crashbash david bash st. charles (193 posts) Registered: 01/28/2008 10:53AM Main British Car: 1979 MGB Rdst V8 project, 1968 MGC GT, 1969 MGB Rd olds 215 |
Anyone know if there is a problem mounting tube shocks on the later ('79) MGB rear axle with the factory rear sway bar?
David, at one point in time I had tube shocks and a factory rear sway bar on my conversion - no problems with interference.
MGBV8 Carl Floyd Kingsport, TN (1518 posts) Registered: 10/23/2007 11:32PM Main British Car: 79 MGB, Buick 215 |
No problem, David.
Mine's a '79 with tube shocks in the back & a factory sway bar. I see what Gary is talking about, though, as there not enough clearance for a coilover. |
NCtim Tim Shumbera Western North Carolina (154 posts) Registered: 01/19/2012 04:35PM Main British Car: |
Gary,
I'm not ready yet but I'd like a set of brackets also. Or, if you decide not to make them, do you have the CAD file for a plasma cutter? Thanks, NCtim |
