3.4 crate engine with iron heads valve seals
Gentlemen,
I have a MGA with a 3.4 crate engine that I would like to add valve seals to. And while I was in there I was thinking about adding a set of 1.6 roller rockers. Has anyone done this to this engine with favorable results? Thanks! |
BMC Brian Mc Cullough Forest Lake, Minnesota, USA (283 posts) Registered: 10/30/2007 02:27AM Main British Car: 1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3.42 Limi |
Re: 3.4 crate engine with iron heads valve seals
It's like doing it on anything else. A little pressure to the cylinders and break the hold that the valve retainers have.
A set of 1.6 ratio roller rockers should work even with a SFI motor. -BMC. |
