WernerVC
Werner Van Clapdurp
Lynchburg, Va
(41 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
hydraulic tappets (lifters)
Posted by: WernerVC
Date: March 11, 2012 09:31PM
I am in the final stages on assembling my rebuild Rover 3.5 L engine.
Not sure what I should do with the lifters. I disssembled them all and cleaned the insides making sure all the parts were not interchanged. My question now is: Do I install the lifters with no oil in it and run the oil pump with a dummy dog and drill or fill them up with oil before installing them in the engine. I did research on the net but got contradictive answers depending who I am listening to.
Your input please. The camshaft and lifters have about 50,000 miles on it.
Werner
mgbrv8
David Hetrick
McAllen Texas
(77 posts)
03/09/2008 12:49PM
MGBs- 1977,1969 Vettes-1965,1984,2003 ZO6 LS1s in MGs
Re: hydraulic tappets (lifters)
Posted by: mgbrv8
Date: March 12, 2012 03:48AM
Fill and then soak them for a day just to make sure.
(3475 posts)
Date: March 12, 2012 08:23AM
The lifter is a pump. Put it in a container of oil and pump it with a phillips screwdriver or something, and you'll feel it get stiff as it fills up.
Colorado USA
(3018 posts)
Date: March 12, 2012 12:05PM
+1 on manually filling the lifters... but prime the engine with a drill motor too.
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(41 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: March 12, 2012 12:55PM
I tried to pump up the lifters but some would not get hard. I mean no resistance when I punch with a screwdriver on the piston.
Does that mean they are bad and should be replaced ?
Werner
crashbash
david bash
st. charles
(193 posts)
01/28/2008 10:53AM
1979 MGB Rdst V8 project, 1968 MGC GT, 1969 MGB Rd olds 215
Posted by: crashbash
Date: March 12, 2012 04:25PM
just to not pass up the opportunity when they are presented try sildenafilling cheeky I couldn't resist...........
(2287 posts)
Date: March 12, 2012 06:43PM
Werner, sbc lifters are so cheap, IMHO. I would by new. Good Luck, roverman.
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(41 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: March 15, 2012 08:50PM
Thanks for the info . I tried to clean the lifters again by taking them apart and soak in carburettor cleaner. Put them back together and pump up with a lighter grade of oil. Now they all work fine.
Werner
