Re: MGB Aerodynamics. Will this work?
Todd
I believe he was using Toyo R888 tyres. I much prefer not having a passenger. Very happy with the aero upgrades. Just need to experiment with angles. Mark |
Hello again all.
Well, it would seem that the rear wing is producing quite a lot of downforce. I know this because my exhaust is grounding at high speed (130mph+) over slight undulations which it never did before. I have had an idea that almost seems too simple, but I think could work to reduce drag at high speed. Just to recap the car is a road legal MGB GT V8 4.8 which is modified for trackdays not racing. I have been experimenting and found the best angle for maximum downforce and the best angle for minimum drag. The virtical distance between the rear wing mounting hole for both these setting is less than 30mm. I was wondering if I could use a strong spring for the rear wing mount each side that would compress at high speed/downforce (80mph+) so giving maximum effect at lower speeds but less effect and less drag at high speed. it would take a bit of trial end error to get the spring rate right and I could use my Gopro camera too see what is going on. Also I could factor in adjustable stops to set maximum and minimum angle. How stupid is this? as it seems just too simple. Mark |
Mark, the super modifieds like those in the picture do the very thing you're talking about, I've never looked at one up close to see how they manage the up and down movement , but the wings definately flatten out at speed and come back up on deceleration. these cars run big V8 engines and are direct drive ( in/out box),, oh yeah,,,, they ARE roundy round cars.
Dave |
Thanks Dave
I like a challenge Now I have come up with a linkage that will effectiveley soften the spring after the initial 20mm of movement. It will take a while but I will post up the vid hopefully of the linkage in action. Mark |
They use "wing cylinders" and you can see them in the photo. There is a controller for it in the cockpit so the driver can adjust it, I think it is some sort of brake cylinder. I am considering the use of these on my wing but will be tying it to the suspension so it works like the mechanical linkage I had before the IRS. Common sizes are 8", 10" and12" travel. I have not seen anything shorter. Speedway sells a hydraulic cylinder now but it is not available in the 8" size. Diameter is 1-1/4". Cost about $140 each. If I use these I will need suspension cylinders with about a 3/4" bore and 4-1/2" of travel. This system holds the ride height constant by applying more downforce if the body lifts.
It would be nice if it was that easy, just add a wing and be done.
If traction is the game then yes. there is a formula to figure out the down force area needed. Down force is like adding weight, so spring rate changes. The front may also need down force to compensate for the rear down force. tires also a factor to include in the formula. Then angle of the wing etc etc. Wings create drag which means that they use hp/torque, top speed reduces. It would be more beneficial to reduce drag first and add the needed down force. I would start by closing every opening in the front, reduce the air intake on the radiator, be surprise how little you need. Many books in this area. I am doing the same with my GT I want less drag, |
Bill
Post up some pictures of what you are doing to the GT, I'm fabbing the front sheetmetal now so would be the ideal time to make changes. Start a new thread so we don't hijack. Edited 1 time(s). Last edit at 10/15/2012 02:03PM by Jim Stabe. |
From my understanding thru folks I have worked with a typical opening to rad size should be about 1" to 6" ratio, but like what has has been discussed previously you still need the pressure differential back of the rad to work.
Dave |
How stupid is this? as it seems just too simple. Too simple? Wait til it breaks, we'll see how simple you think it is then. ;-] you can get little rubber sliders for the shaft of the adjustment piston which will show you exactly how much maximum compression at speed is. Obviously, that won't work for extension. |
Mark, "If" you were to attach the rear wing struts to the rear end or uprights,(unsprung weight), you would not need more spring rate.Using rubber blocks to limit suspension compession, prematurely, can lead to rapid slide of the tires, on that end,(spring of near ifinite rate). I'm not suggesting this, but on early days of winged Indy cars, they did this. Problems arose because the verticals were "triangulated". One failed, there was a crash, and USAC banned suspension mounted wings.Its a good concept, the application was flawed. Footnote, so now high downforce cars can use springs fron the railroad/lol. Onward, roverman.
Edited 1 time(s). Last edit at 10/24/2012 01:43PM by roverman. |
Mark, it looks great, excellent range of adjustment and you could change spring rate or motion ratios for further adjustment
capability, nice fab work by the way. Dave |
You may have a little rocking from side to side so watch for that. If it does, watch out for a harmonic. I think it is stiff enough that you will be OK. It looks pretty good. Not sure how your mechanism works though.
Stunning performance improvement. The Wing and drag reduction linkage works just great. knocked off 3 seconds from my best time at Castle Combe.
[www.youtube.com] |
