denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
1975 MGB 350 SBC bored 0.040 over
Brake proportioning valve
Posted by: denvermgb
Date: August 18, 2012 07:04PM
Getting ready to set up rear Musatang calipers from 94-04 Mustang on my '75 MGB SBC conversion with 7.5 Ford rear diff. Front brakes are stock. Any recommendations on a brake proportioning valve?
Thanks in advance,
Brad
Re: Brake proportioning valve
Date: August 18, 2012 11:43PM
Check the Summit, Jegs, & Speedway sites for the ones they sell with their brand name on them. Generally less expensive than Wilwood or CPP but appear to be the same valves.
denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
Date: August 19, 2012 09:06AM
Thanks Rob. I have looked at lots of options but thought I'd ask here.
Brad
deltadave
dave plumley
unionville TN
(69 posts)
10/24/2010 08:21PM
1953 MG TD Chevy 350
Posted by: deltadave
Date: August 19, 2012 02:52PM
Hey Brad
I use Wilwood valves, but I would assume they are all pretty much alike. Just put is somwhere that is easy to get to so you can tune it to your vehicle.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: August 19, 2012 03:24PM
My conversion uses Mustang rear discs and MG std front discs and has a Ford/Mustang proportioning valve like this ebay item. Car stops straight and true and without the hassle of of dialing in a 'manual' proportioning valve.
[www.ebay.com]
(2465 posts)
Date: August 19, 2012 05:31PM
Brad, you can also use the larger TR8 pads on the front. Same as the factory V8 pads.
denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
Date: August 19, 2012 08:09PM
Graham,
Any idea of the year/part number of the 'Stang valve?
Jim,
I didn't know that about the front TR8 pads. Thanks. I will be updating the front rotors/pads soon.
Brad
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: August 19, 2012 10:48PM
Brad, I'll try to identify the part no and post tomorrow, but aluminum proportionng valve used in Mustang Fox body with disc/disc brakes will work - don't get a prop valve for disc/drum combination.
deltadave
dave plumley
unionville TN
(69 posts)
10/24/2010 08:21PM
Date: August 20, 2012 05:52PM
I hate to start anything, but proportioning valves are specific to each model car. Total weight, weight distribution, wheel base and even tire size effect the amount of brake required at each end. I don't believe an MGB is anywhere similar to a Mustang. Just my two cents, but do some reading on the subject before you decide.
denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
Date: August 20, 2012 07:10PM
I have had some PM's and some responses here so my research has begun. I appreciate everyone who is offering up their input!
Brad
