NAS1966
Norbert Sliwinski
Monroeville
(28 posts)
08/11/2012 05:20PM
1973 MGB GM 2.8 V6
In tank fuel pump
Posted by: NAS1966
Date: August 25, 2012 07:36AM
Did anyone use an in tank high pressure fuel pump?
kstevusa
kelly stevenson
Southern Middle Tennessee
(985 posts)
10/25/2007 09:37AM
Re: In tank fuel pump
Posted by: kstevusa
Date: August 25, 2012 09:14AM
You can view my "how it was done" in the section of this sit. In-tank is probably optimum way to add EFI to our cars. mine is just one way, but it worked for me.
denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
1975 MGB 350 SBC bored 0.040 over
Posted by: denvermgb
Date: August 25, 2012 08:27PM
You might PM Keith Tanner, he has been playing with fuel tanks and fuel pumps for his LS powered GT.
Brad
flitner
John Fenner
Miami Fl
(168 posts)
03/11/2010 10:58AM
1972 MGB 350 CHEVY
Posted by: flitner
Date: August 27, 2012 02:32PM
Yes, I did as well, a pump for TBI GM unit along with sender, ran a 3/8 and 5/16 forward to a pressure regulator with return, so far no problems.
Date: August 27, 2012 06:40PM
Same. I have a Walbro 255lph internal pump with 3/8 feed & return. Currently running a carb so using a bypass regulator that lets 5psi thru to carb (adjustable from about 3 to ??) and the rest goes back to the tank. Plumbed it that way so I'd be ready for FI conversion if/when I get ready to do it.
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: August 27, 2012 08:35PM
Rob,
Who's regulator did you use? I have a tank from Todd and may put it in now with my carb.
Date: August 28, 2012 07:44AM
I'm using a Professional Products 106533 like this but the price has about doubled since I got mine... [www.spiderautomotive.com]
flitner
John Fenner
Miami Fl
(168 posts)
03/11/2010 10:58AM
1972 MGB 350 CHEVY
Posted by: flitner
Date: August 28, 2012 12:02PM
[www.ebay.com]
Here is the one I used on mine.
Date: August 28, 2012 05:59PM
Do a search for bypass regulators on Summit, jegs, or speedway. I saw some in the $60 range. One was a Holley unit.
psmg
Paul Schils
Fredonia, WI
(89 posts)
12/13/2007 10:27AM
1973 MGB-GT, Buick 215 1971 MGB RD, SBF 302
Posted by: psmg
Date: August 28, 2012 07:49PM
Brand Aeromotive
Manufacturer's Part Number 13301
Part Type Fuel Pressure Regulators
Product Line Aeromotive Universal Bypass Regulators
Summit Racing Part Number AEI-13301
Fuel Gasoline
Pressure Range (psi) 3-65
Regulator Style Return
Regulator Location Inline
Boost/Vacuum Reference Port Yes
Boost/Vacuum Rise Ratio 1:1
Gauge Port No
Mounting Bracket Included Yes
Fittings Included No
Rebuildable Yes
Inlet Quantity One
Inlet Attachment Female threads
Inlet Size 3/8 in. NPT
Outlet Quantity Three
Outlet Attachment Female threads
Outlet Size 3/8 in. NPT
Return Attachment Female threads
Return Fitting Size 3/8 in. NPT
Regulator Material Aluminum
Regulator Finish Red anodized
Quantity Sold individually.
Notes The installed low pressure spring will adjust fuel pressure from 3-20 psi, the included high pressure spring must be installed to adjust fuel pressure from 20-65 psi.
Rob,
This is the regulator that I used. I installed it with the new fuel tank from Todd Budde but initially used a carburator and was able to use the weaker spring for less pressure. After switching to EFI, all I had to do was install the stiffer spring and adjust accordingly. One time install.
Date: August 28, 2012 09:50PM
Hmmm... looks ike I should have done more research before I bought the one I got... I didn't realize I'd need a regulator when I switched to FI. Just assumed the injectors would work with the high pressure pump.
kstevusa
kelly stevenson
(985 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: August 29, 2012 07:20AM
Rob, the Ford EFI systems have a regulator and depending if 93 or earlier has the return line requirement. 94 and later 5.0L does not have a return, but modulates the fuel pump pulse i think.
Date: August 29, 2012 07:56AM
More common to see a fpr at the terminal end of the fuel rail, that way the fuel keeps the rail cooler.
