Need an idea
Now that my fan is working right I'm ready to get my A/C going. Thinking I want to mount the drier under the slam panel but I'll need a sight hole so I can see the sight glass. Trying to think of something I can use to finish off the hole. What I have in my head is something like this - something I can paint body color or polish... have Googled but haven't found anything that'll work & look good. Inside of the hole will need to be about 1" diameter...
Edited 1 time(s). Last edit at 08/26/2012 10:48AM by rficalora. |
Re: Need an idea
The instructions on my Nostalgic Air system said not to be concerned with the sight glass on the dryer.
I mounted my drier to the side of the condensor as plumbed by Nostalgic....under the slam panel. |
Re: Need an idea
Rob,
I don't know if this will help, but Vintage Air has a horizontal dryer that you might want to take a look at: [www.vintageair.com] Ted mounted one in the hole on the right-rear of my engine compartment and put a machined aluminum plate over the hole to hide it. The plate was machined to match the plate covering the evaporator unit. The hoses run inside the fender well under a metal cover along with the frontend wiring: |
Re: Need an idea
Question! For those of you who have cut notches the panel in front of the radiator for ac or radiator room, how did you deal with the hood latch mechanism?
Paul |
Re: Need an idea
Re: Need an idea
How about using a camera lens UV filter? You can use a step up or down ring as a backing nut on the other side of the panel if there is enough thread.
[www.ebay.com] |
