Need an idea
Date: August 26, 2012 10:46AM
Now that my fan is working right I'm ready to get my A/C going. Thinking I want to mount the drier under the slam panel but I'll need a sight hole so I can see the sight glass. Trying to think of something I can use to finish off the hole. What I have in my head is something like this - something I can paint body color or polish... have Googled but haven't found anything that'll work & look good. Inside of the hole will need to be about 1" diameter...
Edited 1 time(s). Last edit at 08/26/2012 10:48AM by rficalora.
kerbau53
Geoff Morton
Naples, FL
(109 posts)
08/09/2010 10:27PM
78 MGB Ford 5L
Re: Need an idea
Posted by: kerbau53
Date: August 26, 2012 08:36PM
We used the pax side wheel well.
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Re: Need an idea
Posted by: mowog1
Date: August 26, 2012 10:05PM
The instructions on my Nostalgic Air system said not to be concerned with the sight glass on the dryer.
I mounted my drier to the side of the condensor as plumbed by Nostalgic....under the slam panel.
danmas
Dan Masters
Alcoa, Tennessee
(578 posts)
10/28/2007 12:11AM
1974 MGBGT Ford 302
Re: Need an idea
Posted by: danmas
Date: August 26, 2012 10:42PM
Rob,
I don't know if this will help, but Vintage Air has a horizontal dryer that you might want to take a look at: [www.vintageair.com]
Ted mounted one in the hole on the right-rear of my engine compartment and put a machined aluminum plate over the hole to hide it. The plate was machined to match the plate covering the evaporator unit.
http://www.britishv8.org/MG/DanMasters/DanMasters-BE.jpg
The hoses run inside the fender well under a metal cover along with the frontend wiring:
http://www.britishv8.org/MG/DanMasters/DanMasters-GI.jpg
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
1972 MGB-GT 1979 Ford 302
Re: Need an idea
Posted by: pspeaks
Date: August 27, 2012 10:05PM
Question! For those of you who have cut notches the panel in front of the radiator for ac or radiator room, how did you deal with the hood latch mechanism?
Paul
kerbau53
Geoff Morton
Naples, FL
(109 posts)
08/09/2010 10:27PM
78 MGB Ford 5L
Re: Need an idea
Posted by: kerbau53
Date: August 27, 2012 10:29PM
I'm using 2 of these (Quik-Latch) just outside of the stainless accent strip on an MGC hood. Also strengthened and slightly lengthened the hook of the stock safety hook.
Edited 1 time(s). Last edit at 08/27/2012 10:30PM by kerbau53.
littlebritishcar
Rick Anderson
(15 posts)
11/11/2011 10:25AM
Re: Need an idea
Posted by: littlebritishcar
Date: August 29, 2012 02:19PM
How about using a camera lens UV filter? You can use a step up or down ring as a backing nut on the other side of the panel if there is enough thread.
[www.ebay.com]
