Fuel Sending unit
I was just pondering my electrical schematic and the following question popped into my head. I’m using an MGB fuel tank with a MGB fuel quantity sending unit, but I have a Dolphin gauge (shark, without the fish logo). I’m concerned that the sending unit resistance and the gauge won’t match. Is that going to be a problem, and if so, is there a device to put in line so the gauge will be accurate?
Edited 1 time(s). Last edit at 09/09/2012 07:25PM by pspeaks. |
Re: Fuel Sending unit
Same problem (different gauge maker though). I disassembled the MGB sender, did the same to the sender that matched the gauge, reassembled the B unit using the resistor from the gauge sender. My second time doing it this way. Was the same on the Cobra replica I had. That one used Dolphin gauges. Nice product BTW.
Both times, works just fine. |
Thanks guys, looks like I do have to do something, so now I guess I have to decide which way I want to go. Either way it doesn’t seem too difficult. The gauge on the t-bucket I had never worked worth a darn so I used a stick on it every time I passed a gas station; not so practicle on my GT
Paul Edited 3 time(s). Last edit at 09/10/2012 10:42AM by pspeaks. |
Great idea Phil, I might just try that. In fact I'm going to put a new tank from Moss on the GT and center it with all new hardware. Thanks a lot, knowing you guys have done it with success makes me feel a lot better.
Paul |
