Re: Aero / cooling front sheetmetal
Quote: Why wouldn't the air passing through the radiator do the same thing? |
It does, but why would you want to add pressure with air that isn't doing any cooling to impede the air coming through the radiator that is actually doing some work. The radiator is a restriction to flow so air will take the path of least resistance if it is available - around the radiator. Air flows from high pressure to low so you want to keep the area behind the radiator at as low a pressure as possible. The closer the pressure behind comes to matching the pressure in front the slower air will flow until pressures equalize and the flow will stop. At rest the two pressures are equal and no air flows, hence the fan.
I finished up the top section baffleing.The top edge of the baffle will have a 1" bulb seal that will press against the underside of the hood. The bottom portion will be part of the front valence and will have an opening only as wide as the radiator core. If you look at the front of the core you will see a ding, a hammer fell and bounced against the core denting one of the tubes and the surrounding fins - stupid, stupid stupid...
All that extra room and... HEY! where's all the extra room!??
It is really looking good. But radiators are hammer magnets. No matter what you do to protect them... I feel your pain. Jim |
