hirot
Ian Hart
Ashbourne UK
(88 posts)
06/01/2011 05:15AM
1971 MGB GT (conversion) Rover 3947 R380 gearbox
Thin water pumps
Posted by: hirot
Date: November 20, 2012 03:03PM
I have a 3.9 V8 I have put into my MGB GT and was trying to fit a puller fan rather than use the two pusher fans. However, the standard P6 water pump has a long nose, which is not used and stops about 40mm from the radiator.
Has anyone used a QCP2059 or Buick pump or cut off the front of the P6 pump. I have a standard SD1 timing cover and have the usual GWP310 pump, which wasn't cheap so I am loath to just grind the front off and then try and thread it and then align the pulley.
I have read a thread where a pump was cut down but can't remember which timing cover was used.
An alternative is to tilt the radiator forward about 3/4" which appears to give me space....but how far does the engine move under braking and acceleration ?
Any help will be greatly received.
Regards Ian
Edited 1 time(s). Last edit at 11/21/2012 01:58PM by hirot.
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Re: Thin water pumps
Posted by: mstemp
Date: November 20, 2012 03:39PM
Ian,
I think you can use a Buick 300 WP. Over here they are about $50 brand new. May take some fiddeling to line up with the SD1 balancer though. There was a recent post on this at:
[www.mgexperience.net]
Date: November 21, 2012 05:54PM
Does this old article help?
[www.britishv8.org]
mgbazza
Barrie Egerton
Sydney Australia
(24 posts)
01/20/2009 07:40AM
1978 MGB GT Rover 3.5
Posted by: mgbazza
Date: November 25, 2012 10:08PM
This is a water pump from a P6 Rover. The end was chopped off & the flange ,was drilled & tapped 10/32. The pulley was then screwed onto the flange.I left the spigot in situ as a guide for drilling.
Date: November 26, 2012 08:22AM
The Buick 300 pump comes in two versions, aluminum and cast iron body. Other than that I think they are the same.
