advanced autowire harness install
I'm Installing a advanced auto wire harness.I have a new Moss motors turn signal switch and I'm using the supplied autowire connectors. Here's the problem. Out of the turn signal/dimmer/horn sub harness is a black wire that's not shown on the schematic. Is it safe to assume that it a ground wire.
restorejag Mike Alexander Richmond Va. (24 posts) Registered: 02/19/2008 05:53PM Main British Car: 1974 MGBGT 1958 MGA 1968 JAG XKE Ford 302 215 OLDS |
Re: advanced autowire harness install
Alan,
That is the ground wire for the horn. Mike |
