John316m John Millard Kidderminster UK (29 posts) Registered: 05/29/2010 04:13PM Main British Car: 1972 MGB - 1976 MGB V8 Stock (but tuned) - Rover V8 |
MGB Ball Jointed Front Suspension
Hi,
Has anyone used Mustang (or any other) spindles to convert their front suspension to replace the king pin assembly with top and bottom ball joints, fabricated suspension arms and coil over dampers. I know you have the Fast Cars conversion, but all the coil over conversions over here, with the exception of the MG Owners Club one, retain the king pin assembly. Thanks John |
Re: MGB Ball Jointed Front Suspension
Here's another bolt-on alternative:
Classic Conversions Engineering's MGB Coil-Over Front Suspension |
Hi Curtis
That is exactly what I had in mind, but they do not seem to exist in the UK. Looking at the photographs and the other products they sell am I correct in thinking that they use the Wilwood hubs, bells and discs brakes ? Thanks John |
I expect so. Why not e-mail Bill Guzman and request a quotation for shipping to Kidderminster, Worcestershire?
John, I went with the MGRV8 from suspension on my car in order to get the ball joint suspension, telescopic dampers and 4 piston ventilated brakes. Its a direct bolt in swap and might not be too hard to find at a breakers yard over there. There was a thread about this a few years ago over on the MGB forum that might have some other ideas [www.mgexp.com]
nobogez07 Doug Brown Webster, South Dakota (58 posts) Registered: 12/11/2012 05:38PM Main British Car: 1971 Mk II MGB coupe 1992 302 Ford H.O. EFI |
John
I have the Classic Conversions suspension for my rebuild. I've disassembled it to powdercoat it my own color. There is no question it's the real deal!! Extremely well made and designed and absolutely everything you need comes with the kit! The only bad part for me is the hub pattern is for a 5 bolt setup. I have Panasport 15" which aren't going to work. Want to buy some brand new wheels? |
