Goto Page: 12Next
Current Page: 1 of 2
NCtim
Tim Shumbera
Western North Carolina
(239 posts)
01/19/2012 04:35PM
Curtis Updated His EFI Install
Posted by: NCtim
Date: May 17, 2013 07:11PM
Earlier this week he's got a new photo of his super clean fuse block and wiring behind the dash. Looking for more on his logic and decisions for why he's working this out. He is an engineer so maybe it's, "just because."
Tim
Re: Curtis Updated His EFI Install
Date: May 18, 2013 03:56AM
You're too kind.
The car still needs a lot of work to be roadworthy in time for the meet. Fuel pump and lines. Programming/tuning. (Not to mention tires.)
I added a couple more photos to the gallery page late tonight to show more recent progress.
Here are two snapshots that didn't fit. Engine wiring is in place, but requires more detailing (conduit, etc.)
hirot
Ian Hart
Ashbourne UK
(88 posts)
06/01/2011 05:15AM
1971 MGB GT (conversion) Rover 3947 R380 gearbox
Posted by: hirot
Date: May 18, 2013 05:15AM
That is a piece of art....its beautiful.
(4512 posts)
Date: May 18, 2013 08:24AM
Looking good, Curtis!
Tires? Seems like you just bought those Falken Azenis. How many miles are really on them, or are you just looking for something even stickier?
NCtim
Tim Shumbera
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: May 18, 2013 10:08AM
That's some real nice work.
Tim
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
74 MGB-GT 3.4 V-6 crate, 5 spd
Posted by: lawnvett
Date: May 18, 2013 05:35PM
wow tha tlooks sooo good
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: May 18, 2013 09:54PM
That is way to cool looking Curtis......What lbs injecters?? and what MM size is the throtle body opening. Those injectors look like my ls1 injectors. Even the sensors look GM , TPS, ICS...??
Calvin
Date: May 19, 2013 03:13AM
I reckon I've only got about 20,000 miles on the tires, but they're smack worn out. A track day when they were new killed a lot of tread. I bought them shortly before BritishV8 2008 (Wisconsin), so by that measure they've done alright. Not sure what tires to buy next.
MAP, IAT, TPS, etc. are GM. I believe the throttle body is Chevy 4.3L V6. Its bore is 72mm, but there's a diffuser on the butterfly so functionally it's smaller. I'm told that Chevy used the same throttle body on a couple different engines, with various sizes of diffuser.
Injectors are Lucas. They came with the lower manifold and fuel rail from a Rover 3.9L. They've been cleaned and tested, and according to the report that came back with them each one flowed 58cc/min (22.10#/hr).
I spent today at my mother-in-law's, but hope to turn some wrenches tomorrow night. I'm keen to make some progress on a fuel tank solution.
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Posted by: MGB-FV8
Date: May 23, 2013 04:02PM
Very impressive and super clean looking conversion; did you do it mostly yourself?
BMC
Brian Mc Cullough
Forest Lake, Minnesota, USA
(383 posts)
10/30/2007 02:27AM
Posted by: BMC
Date: June 18, 2013 11:48PM
I really like your lightweight polycarbonate rear quarter windows.
What is the material that you used for your fuse and relay panel cover? That looks Great. Did you send the product through your standard printer and cut it out or have a special machine build that cover for your application?
What size pistons do you have in the front calipers? It would appear that you have more caliper than the stock master cylinder could handle unless you have changed something i am not thinking of.
Thanks,
-BMC.
Date: June 19, 2013 02:04PM
The fuse block label is just laminated cardstock. I printed the cardstock on my laser printer. After laminating, I cut it out with an X-acto knife. Applied spray adhesive to the back side. It'll be easy to change down the road if I add a relay or...
I don't recall the piston size offhand, but the front brake kit is Classic Conversions part number CC-115. At the meet last week, Graham Creswick and I drove each others cars. We've both recently installed that same kit. Graham has a larger (1" bore) master cylinder, OEM-style (Ford) proportioning valve, modified pedal ratio, and discs at the rear. Most apparent result: firmer brake pedal. However, both cars stop. Yes, I'd rather have Graham's brakes - but I can't complain about how mine served through Monday's track day.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 19, 2013 08:47PM
Quote:
I don't recall the piston size offhand....
My notes indicate they are twin pot 1.75" dia.
(2463 posts)
Date: June 21, 2013 02:59PM
Curtis, Your fuel injection setup looks great! Have you thought about updating your valve covers? OBrian Truckers has no name 215 valve covers.
[www.obrientruckers.com]
Date: June 23, 2013 02:54AM
Thanks, Jim. Those O'Brien covers appear to be a nice alternative to Offenhauser covers... but I feel my old steel covers look better with each passing year. I like that their styling is distinctly "Buick" (and without actually having the word Buick on them either!)
I see that O'Brien makes all sorts of 1950s-style club plaques. We saw hundreds of those at the Speedway Motors museum last week. It got me wondering if, perhaps, we should commission a run of "BritishV8" plaques. They might look really good on man-cave walls!
(2463 posts)
Date: June 23, 2013 12:06PM
Curtis, I ran the stock valve covers for years on early V6's and 215's and think they look fine. Mine were silver/aluminum though. Keep us posted on the progress. You might even convert an old carb guy like me!
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Posted by: MGB-FV8
Date: June 23, 2013 06:14PM
WOW, you nailed it. Very clean and OEM looking........
classic conversions
bill guzman
(294 posts)
01/09/2008 01:58AM
Date: June 26, 2013 11:39PM
Very nice Curtis, sharp looking engine. Well done!!!
Are you saying you are going to do a write up on the brakes.
Correction 4 piston dynalite caliper.
I use a 6 piston caliper, just because :-)
Edited 1 time(s). Last edit at 06/26/2013 11:43PM by classic conversions.
(6469 posts)
Date: June 27, 2013 09:32AM
I really like the way Curtis' engine compartment looks with the black OEM valve covers and his custom plenum. Very clean and clearly performance oriented. I drove his car around Omaha and I must say the performance is excellent. He still has a little more he will be able to wring out of the new EFI system but was very close at that point and there was nothing objectionable in the engine's operation. Very well done Curtis!
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
1972 MGB-GT 1979 Ford 302
Posted by: pspeaks
Date: June 27, 2013 12:42PM
I must concur, I went for a ride with Curtis in Palestine and was completely impressed, and that was before the injection.
Paul
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: June 29, 2013 07:29PM
Driving Curtis's car in Palestine was the second GT that I've driven. I liked the GT enough in just driving two of them to want one for Brenda and I. I told Curtis that if Brenda drove his car she would want a GT. Curtis's car feels light and you can tell when you drive it. It has driven me to a new illness. The first GT I drove was Robert Milner's when I bought his Miata seats from him.
What I would like to see someday is for Curtis to win the lottery, then watch him build himself a GT with his thought process without money cap.
Goto Page: 12Next
