Heater hose cut off valves
Date: July 27, 2013 02:15PM
Here is a good topic for discussion I think. We've come up with various ways to use the original valve and several aftermarket valves, and here lately I've been seeing comments about something called a bypass valve. What is it, and what does it do? What configurations is it available in? Is there a ready source that is good for our applications?
Those are my questions, as for answers I have some speculation and maybe some of you can elaborate on it. I think the idea is to prevent hot water from entering the heater core from either the supply or the return hose. Apparently even with the supply hose turned off a significant amount of heat can get in from the other side. So does a bypass hose turn off both sides at the same time? Does it connect the supply and drain hoses together (why would it?) or something else entirely? I'm ready to hook up my heater and would like to know. A new heater control valve would be good, the right one would be better.
Jim Stabe
Jim Stabe
San Diego, Ca
(829 posts)
02/28/2009 10:01AM
Re: Heater hose cut off valves
Posted by: Jim Stabe
Date: July 31, 2013 11:24AM
Here's an electric one
[www.lategreatchevy.com]
Date: July 31, 2013 11:31AM
Looks interesting but does it allow partial opening to control heat? The description says it uses a "switch" which would seem to indicate on/off operation.
On the plus side, if it *can* control the opening it might not be hard to fit into the stock control position in the dash.
Jim Stabe
Jim Stabe
San Diego, Ca
(829 posts)
02/28/2009 10:01AM
Date: July 31, 2013 12:07PM
Since it can be used to replace the stock vacuum unit I would imagine that you could modulate it for heat control. I'd call the vendor ans ask.
Date: July 31, 2013 04:46PM
The more I think about it, the more I think the original cable control is just fine, at least for now. But the valve only controls one side. Chrysler had a 4 port valve Everco # 74643 but I have no idea how it worked internally. Seems to me you'd want to completely shut off the flow on both sides of the heater core at the same time and at least for the older type coolant systems most of us are using, bypassing the flow would bypass the radiator too so shutting it off completely would seem a better answer as it would not decrease the cooling of the system by bypassing the radiator.
I'll probably re-use my old cable controlled single valve for now, and maybe never change it. But when I do the new dashboard I may want to look at this again.
hirot
Ian Hart
Ashbourne UK
(88 posts)
06/01/2011 05:15AM
1971 MGB GT (conversion) Rover 3947 R380 gearbox
Posted by: hirot
Date: August 03, 2013 01:14PM
Don't know if it helps but I used the original dashboard cable control and an RV8 inline shut off valve and it works a treat. It turns the flow off and on to the heater matrix easily unlike the original MGB valve.
The valve fits in easily in the hose that returns down the side of the inlet manifold to the pump.
Can't see why you would need to shut off both ends to the matrix as once you have stopped the flow thats it. My matrix just goes cold which is what I expected.
However, with louvres in the bonnet when my twin fans come on I get hot air comming through the face vents which will be a useful feature in the winter and will no doubt keep the frost off the screen.
Ian
burner1
Gary W
(212 posts)
09/24/2011 09:59AM
Posted by: burner1
Date: August 09, 2013 02:19PM
This is what I have used for the last 7 years:
[www.summitracing.com]
http://www.rc-tech.net/cars2/mg2/cleanup/wat3.jpg
danmas
Dan Masters
Alcoa, Tennessee
(578 posts)
10/28/2007 12:11AM
1974 MGBGT Ford 302
Posted by: danmas
Date: August 09, 2013 02:37PM
That's the one I'm using.
Oldbloke
Jim Legg
Napa, California
(94 posts)
01/24/2013 03:24PM
1970 Rover P6 3500S Rover 3.5L V8
Posted by: Oldbloke
Date: August 16, 2013 12:02PM
Using stock 'B' valve with modified bracket on my 3.4L.
