mstemp Mike Stemp Calgary, Canada (222 posts) Registered: 11/25/2009 07:18AM Main British Car: 1980 MGB Rover 4.6L |
Re: LS4 Into an MGB
Scott,
No my Rover 4.6 will have to do. Just thinking of others. We now have Bill Guzman working on the Ecoboost, LS would be another great new option for new conversions. Unlike yourself I am not a pioneer! Congrats on your build. |
Scott68B Scott Costanzo Columbus, Ohio (561 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
Re: LS4 Into an MGB
Thanks Mike! I really appreciate it. Just an FYI, I built my car for myself, not with the intention of developing a kit. Perhaps I would have done things a little differently? Not sure as I never even considered the possibility. I have zero time to get involved with developing a kit or even just components at this point in my life.
Re: LS4 Into an MGB
Thought I'd do a quick update. My car is back on the road and I took it out for a few rides to continue to sort it out. I was pretty pleased overall. Bottom line, the car appears to be running about 10 degrees cooler than it did last year and the Volvo fan takes the heat away much faster than my old fan did. I should mention that I've run the old setup on days that were in the low to mid 90s many times with no issues but I worried about how the cooling system would perform in a traffic jam on days in the high 90s and above. That was the motivation to include the Volvo fan upgrade this winter.
So a few things have changed compared to my old cooling system setup. Obviously, the biggest change was the addition of the Volvo fan but I made some other changes that may have had an effect as well. As I mentioned earlier, I reinstalled the heater back into the car which required me to add some 90 degree fittings at the water pump in place of the plugs I installed originally. So in my research to make these changes I discovered a few inconsistencies in what I was doing. I needed a 90 degree thermostat housing that pointed straight down for my application so I got an aftermarket unit that swivels 360 degrees. It specified that a Gen 1 SBC thermostat should be used and that is what I did. Seemed to work ok. What I realized after my research is the machined surface/opening in the water pump on the wall that separates the hot and cool sides within the pump is there for a reason. Duh! You can see it in the pic below. The protrusion you see to the left contains the inlet/outlet from the heater core. This is pretty obvious but for the heater ports in the water pump the hot side comes off the hot side of the pump and the cool side is the return from the heater core. The LS thermostat has a spring loaded valve that covers the machined surface/outlet inside the pump. See picture below. During warm up the valve comes off the machined surface and allows the hot side to blend with the cool side internally within the pump. Some say it's to keep coolant flowing through the block to avoid pump cavitation. As the engine reaches operating temperature the blending is reduced as the valve closes when the thermostat begins to open and more of the hot coolant is directed to the radiator. The point to this is with the SBC thermostat, it's possible not enough of the hot coolant is going through the radiator which could reduce the efficiency of the system. I believe I could have had issues if I didn't make changes because with the addition of the heater, even more hot coolant would have been bypassing the radiator as I'm using one of the 4 outlet heater valves. So when the heat is off the coolant is directed back to the cool side of the pump bypassing the heater core. Although my original setup wasn't optimal I think it worked because I had plugs in the heater outlets in the pump. Hope this makes some sense. I had to modify the LS thermostat slightly so it would fit into the thermostat housing but it wasn't a big deal. I attribute my cooler running while going down the road to two things, using the correct LS thermostat, and going from a 12" fan to the 15" Volvo fan which is allowing air to flow through the radiator a little easier since the hole in my shroud is now bigger. FYI, I usually log during my drives and I'm comparing a log I did last October with the two I did the other day. The weather was very close temperature wise on those two days. Here is a current picture of the engine bay. You may notice that I finally moved the air filter from behind the radiator into some cooler air. I logged incoming air temperatures in the 160s and above on hot days last summer. This change should help with that. Oh, before anyone mentions it, I know this filter is small and and I hope to go to a larger one before the meet. I would bet it is hurting flow at high RPMs. I still have to do the seats and further clean up/sorting from my winter tasks. Really looking forward to the meet! |
Re: LS4 Into an MGB
Looking good Scott, a proper conversion to be sure. Interesting note on that thermostat. Robertshaw made thermostats that worked in a similar fashion (and still does I expect). I'm most familiar with the one used in the I-H SV series V8 engines, which also closed off a port in the bottom of the housing when it opened.
Re: LS4 Into an MGB
Beat me to it, Scott. :)
Looks like you have room for a longer round straight or round tapered air filter. Here the one I believe come with K&N's Air Charger kit for the Impala, Monte Carlo, Grand Prix 5.3L [www.knfilters.com] I much prefer the new color of the fan cover/shroud. |
Re: LS4 Into an MGB
Thanks guys.
Quote: I figured you'd have something to add Carl which is why I tried to beat you to it! 😊 Quote: Yeah, it's all new. I had to move the radiator forward a little to accommodate the Volvo fan so I decided to do it over rather than trying to adapt the original. It's very visible so it has to be right. I applied the lessons I learned from the first time too. I went with semi-gloss rather than satin this time. It's not perfect but I think it looks pretty good. |
Re: LS4 Into an MGB
Nice job and thanks for all the documentation
I'm trying to get my head around balancer/crank/timing cover compatibility... you posted this on page 9..... "I also replaced the timing cover. The main reason I did this was the original LS4 timing cover has the cam sensor positioned 180 degrees from the position of the RWD LS motors. Obviously, the signal from the cam sprocket reluctor will occur at a different time. I did a lot of investigation but couldn't tell if the 0411 looks at a rising edge, falling edge or just an edge and didn't want to take the chance of finding out the LS4 cover doesn't work when everything was together. An added benefit is the water pump fits without having to modify the timing cover. .... If I'm understanding correctly, you are saying you still retain the original LS4 crank and cam ...but with a RWD timing cover? If so, which RWD timing cover did you use? Or maybe they are all the same though? (I haven't had any luck finding that info yet).... I worried that the truck timing cover would protrude too far and hit the balancer so that's why I was curious if that's a truck or a shallower version. Edited 1 time(s). Last edit at 08/02/2017 07:18PM by standard32. |
Re: LS4 Into an MGB
Hey Kenny,
Thank you! Quote: Yes, I'm using the original LS4 crank, cam, cam spockets/chain with an "LS2" timing cover. I took the old timing cover off and directly placed the new one on the motor. It was from a car motor I believe. I got it off of a guy on LS1Tech. The dimensions of the new timing cover appear to be the same as the LS4 cover (except for the position of the cam sensor) and it's been on the car for close to 5,000 miles now with no issues. I'm pretty sure the truck covers are the same and will interchange but you should double check that yourself before buying one. You probably already know this but the original LS1 had the cam sensor at the back of the engine and with the LS2 it was moved to the front and placed in the timing cover. The LS4 is of the same "generation" as the LS2, in regards to the timing cover/position of the cam sensor at least. Tell us a little about what you intend to put the LS4 into. It's ok if it isn't a British car. :) What computer are you going to use? |
Re: LS4 Into an MGB
Very cool project! Thanks for sharing. I really like your garage too!
I'm quite sure that you'll be OK with the truck timing cover. I'm just cautious with advice because I don't want to lead someone down the wrong path. I didn't take any measurements but the crankshaft was still recessed into the pulley when it was fully seated on the LS4 crank. I'm not sure there was 10mm of space left but at least there was something there. Keep us informed how this works out for you if you don't mind? I think this will be very useful information. |
Re: LS4 Into an MGB
Hello Scott it has been a while since i have talked to you.
I have been driving my TR6 (Gm 3400 v6 engine) for a while now and I have 2900 miles on it now. When I switched out the TR6 diff which I had set up with a reluctor wheel and a 2003 Olds Alero vehicle speed sensor I installed a Nissan r200 diff and I used one of the abs sensors for a vehicle speed sensor. It seems that the Nissan abs sensor does not talk to the ecu and the air idle control system is not working as well as it could. So I am looking at re-using the Alero speed sensor. The alero speed sensor has two wires one is yellow and the other is purple. The last time i used this sensor I did not pay attention to these colors and I hooked up the sensor to the two wires that go to the ecu. Now I am wondering if I need to make sure the wires goes to the proper connectors on the ecu. Or does it make any difference? When you set up the vss for the ls4 engine did you have to make sure that each wire went to a respective hookup on the ecu? This stuff drives me nuts anyways thanks for your time and consideration. Cheers Byron |
Re: LS4 Into an MGB
Hey Byron, I'm just seeing this. Can't believe it's been two years since there has been a post to this thread! Time flies.
When I did mine, I did some research to make sure I wired it correctly. I'm not 100% sure it makes a difference but I can tell you that my VSS works. My cruise control works and the speed shows up in my logs. What ECU are you using and what operating system is installed on it? There should be tags on the unit with that information. Are you able to log and are you sure nothing is being returned? I can tell you that the configuration in my ECU has been updated to account for the pulses I send to it with my 4 tooth reluctor. It may be helpful to determine the number of pulses per mile the code you have in your ECU is expecting and then compare it to the number of pulses/mi you're generating with your setup. It is possible the pulses you are generating are too low or too high to be recognized by the code in your ECU. I had that happen with my V6 ECU. Let me know if you have any other questions. Hope you've been doing well. Scott |
Re: LS4 Into an MGB
Thanks Scott for your reply.
I dug into the GM manual that my friend copied to do the electrical on my car. The manual shows that the two wires at the ECU are purple and yellow which match the wires on the VSS. Today I am going to switch the wires where I spliced the Nissan abs sensor and see if there is any change. If nothing changes I am going to fab up a bracket and mount the GM VSS and make sure the wires are connected properly. The reluctor wheel will be the mounting hub on the passenger side of the diff, this hub has six lugs. The original setup had a reluctor wheel with 8 blades and it seemed to work better than it does now. Hopefully it will work with six lugs. I will keep you posted as to what happens. Cheers Byron |
