BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (5833 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Re: LS4 Into an MGB
Scott, from that last shot it looks like you might be able to extend your rack pinion shaft a couple of inches and clear your exhaust ports by getting the u-joint back into the firewall cone. If you have access to a lathe or someone with one it's pretty easily done, or you could run down here one day and we could do it. Something to keep in mind. The more direct the steering the better. Also since the cone is toast it wouldn't take much to modify that too and there is a little give in the column position.
Scott68B Scott Costanzo Columbus, Ohio (542 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
Re: LS4 Into an MGB
Quote: Jim, Thank you for the offer! With some luck, I should have the motor positioned by the end of the weekend. It will answer several questions. I'll keep you informed. Scott |
Re: LS4 Into an MGB
Made some good progress again yesterday but still have a ways to go. I got engine close to where it will ultimately live and was curious about hood clearance. I was very happy with the what I found.
The next couple of pictures show what I have in mind for the final layout of the engine bay. Again, it is what I was hoping for when I selected this motor. Of course it isn't done yet so things could change. Further changes to the firewall were needed to get the engine where I wanted it. The most significant change was to the heater shelf. I wasn't really concerned with maintaining the original heater box but I believe I can modify it to fit. This will be a phase 2 task, for phase 1 I'm going to put sheet metal covers in place. You can see on the left side that the opening has been enlarged as well. #8 spark plug will be living back there and I need to provide some clearance and access to it. More trimming will be needed there. The right side is pretty much the same although I did do some trimming on the back side to fit the engine. I was running out of time but I mounted the bellhousing on the motor and quickly tried to fit it. The oil pan was hanging up on the crossmember as I was trying to angle it into the engine bay. I will be trimming it a bit more. The next step is to ensure the engine/transmission combination fits properly. For those of you who might be considering this swap, keep in mind that I'm working with a chrome bumper B and my goals for this conversion are driving engine placement. I know nothing about rubber bumper B's, but I understand that the front crossmember is deeper and the firewall is modified for the Rover V8. It might be possible to fit an LS4 in one with no or minimal modification. It would be interesting to see. I would expect even more options if you're running a Fast Cars crossmember with a chrome or rubber bumper model. The most interesting news from yesterday's efforts (well, interesting to me at least :) ) is it looks like it may be possible to route the headers without modifying the steering. I don't have any pictures at this point but the u-joint falls between #5 and #7 exhaust ports and the shaft appears to be low enough to allow the header pipe to fit. We will see. #7 spark plug is pretty close to the u-joint and I don't believe the original boot will work so that's another issue on the to do list. That's it for now. Scott |
Re: LS4 Into an MGB
Very interesting.
74ls1tr6 Calvin Grannis Elk Grove,CA (1150 posts) Registered: 11/10/2007 10:05AM Main British Car: 74 TR6 / 71 MGB GT TR6/Ls1 71 MGB GT/Ls1 |
Re: LS4 Into an MGB
Hi Scott,
I'm kind of right there where you are at cutting the fire wall out. On the passenger side head, it does sit father back on that side than the driver side. How much room do you have there with what you cut out already? I noticed you cut out some of the center section out. What measurement did you leave yourself from the head to the center section?? So far I just cut straight off that shelf along side where the head goes, but I do have a 71 which may have more room. I did move my radiator all the way up to the cross section up front. I'm using a 24"wide x 19" tall radiator. So I also cut into the frame rail all the way out to the inner fender. Welded a c channel back in to reinforce the area. Bought a HF plasma cutter....should have had one along time ago!!! Cut for engine clearance and cut for Vintage Air clearance in about an hours worth of work. It would have taken me days to a week to cut out what I did with a mini grinding wheel or Saw's all. Looking good Scott !! |
Re: LS4 Into an MGB
Hi Calvin,
I was wondering where you were with your B. I'm leaving myself about a 1/4" between the motor and the firewall. I'm cutting the minimum into the firewall and I'm following the contours of the engine which is why part of the heater plenum is still there. Your 71 and my 68 should be exactly the same at the firewall/transmission tunnel. Outside of some touch up I'm done with my trimming except for by the #8 spark plug. What are you doing there? Sounds like you're making some great progress too. The plasma cutter sounds great...I would have to be careful to not get carried away with it. :) Say hi to Brenda Scott |
rficalora Rob Ficalora Willis, TX (2636 posts) Registered: 10/24/2007 02:46PM Main British Car: '76 MGB w/CB front, Sebring rear, early metal dash Ford 302 |
Re: LS4 Into an MGB
RE: Bought a HF plasma cutter....
I told you they are cool. Still wish i hadnt sold mine, but needed the money at the time. Calvin - are you using an LS4 too? |
BMC Brian Mc Cullough Forest Lake, Minnesota, USA (380 posts) Registered: 10/30/2007 02:27AM Main British Car: 1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3.42 Limi |
Re: LS4 Into an MGB
After reading that I wanted to report you to the moderator but then realized he is on your side. Herumph. I guess this is not a Purist site. On a more serious note, I have been following your progress with great admiration. Do you have a photo of the pulleys and how much clearance you have between those and the steering rack and if that was at firewall cutout #1 or the second firewall trim? Without seeing the front, I can't quite tell how the rear trimmed out fits into this equation. Thanks for keeping us post Scott! -BMC. |
Re: LS4 Into an MGB
Brian,
I don't have a photo of my current pulley clearance but I'll get plenty once things are in place. For cutout #1 I had just enough room to fit the engine between the firewall and the steering rack. There wasn't enough room to tilt it at that point. The second trimming allowed me to tilt the engine into the proper position. I'm aiming for just enough room between the rack and the front pulley to allow a belt to be slipped through in case it needs replacing so that will be about 3/16" give or take. I also had to allow for the bellhousing at the upper two bolts. The bellhousing is an inch thick in that area not counting the two bolt heads. That is why you see the heater plenum cut out the way it is. I am going to rebuild the plenum when I put the firewall back together so much of what you see missing will be replaced. Hope this answered your question. Scott |
MGBV8 Carl Floyd Kingsport, TN (3791 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Re: LS4 Into an MGB
The crankshaft is 13mm shorter, but the main thing is the accessories are more compact & driven by a single belt to save space. It's a 5.3L vs 5.7L Comes with LS6 heads, though. Lots of upgrade potential
I'm sure Scott has read this several times. I'll stick it here for future reference: Quote: |
Re: LS4 Into an MGB
[www.gmls4.com]
At the wheels, no less! Quote: Edited 2 time(s). Last edit at 11/09/2013 04:46PM by MGBV8. |
mgb260 Jim Nichols Sequim,WA (2013 posts) Registered: 02/29/2008 08:29PM Main British Car: 1973 MGB roadster 260 Ford V8 |
Re: LS4 Into an MGB
He forgot to mention the heavier valve springs that came in the cam kit. Max power at 7000 RPM! It would be beneficial to advance 4 degrees to move power curve down. Plus if he milled the heads .030 for that extra .5 from 10 to 1 stock it would be over 400HP!
Edited 1 time(s). Last edit at 11/09/2013 04:56PM by mgb260. |
Re: LS4 Into an MGB
Yeah, the LS4 has some potential but I should notice a difference going from about 170 hp to the stock 300 hp I would imagine. :)
Made more progress yesterday. The engine/transmission is in the car at the moment. Still need another day or two to finish the fitting phase. It's amazing how fast the day goes. I spent more than 8 hrs. yesterday and it felt like I was at it for only 3 hrs. Here are a couple of pictures that show how the bellhousing is fitting. This last one was a quick shot at the end of the day showing the transmission is actually in there. It is tight but it does fit. Won't have any time to play with the car next weekend but I'm hoping to get a good start on fabricating the motor mounts Thanksgiving week. Scott |
Re: LS4 Into an MGB
Re: LS4 Into an MGB
Jim,
I'm going with the Barry 22000 mounts per a recommendation by Curtis. Specifically, the 22001-14. I had an unexpected hour to play yesterday so I worked to position the motor a bit more. You can't tell very well from the picture below but the motor is sitting on some temporary "mounts" at the front and I have the transmission cross member in place and supporting the rear. The only place it is touching the body is at a bolt at the rear of the head on the driver's side that I'm using to hold the chain for the hoist. That, of course, will be removed. The setback is just where I wanted it and it is tilted back about 3 degrees. I think I'm going to lower it maybe 1/8" from where you see it here. There are many details and I'll do a more complete write-up when I'm sure it is in the final position. |
Re: LS4 Into an MGB
Is looking good, the only problem I see and it is not a big deal, is the throttle pedal. It is going to be the same issue as the Cobra.
Avoid solid mounts on the aluminum blocks, although the blocks are very strong, a few LS engine mounted solid found themselves with holes in the side of the block at the drag strip seen them. Use some sort of cushion. Great work. |
