Re: LS4 Into an MGB
As an alternative to the bright (expensive) ceramic coating, I have had good luck with the black satin coating from Techline.
[www.speedwaymotors.com] |
Re: LS4 Into an MGB
I've ben using Tech Line coatings for many years. Good stuff. You can buy direct from them and save $$$.
[www.techlinecoatingswebstore.com] |
Re: LS4 Into an MGB
I'll endorse Techline too. I've used their CermaChrome with excellent results but they have a no-polish version that would be easier and claimed to be about as good.
Re: LS4 Into an MGB
a bit off topic of the thread, but does the ceramachrome look like chrome - as in is it a viable alternative to plating. Plating prices seem to have about trippled in recent years.
Re: LS4 Into an MGB
Quote: In a perfect world, we are always moving down the road. No stop lights, no traffic jams, no incredibly slow drive-thrus. :) These days you can just about count on some kind of traffic issue on the interstate when traveling. I can't state that you will have big horsepower gains with ceramic headers. Jet Hot & Swain Coatings do claim better than 50% reduction in radiant heat & surface temps of the headers. That equates to a significant reduction of underhood temps when not moving. Might help with too warm footwells in the Summer, too. For those that don't have holes in their fenderwells, the fan is not always able to push all that hot air out of the engine compartment. In 13 years my car has never, ever overheated. Even in Texas. Ceramic coated headers & Y-pipe, engine driven fan (instead of puny aftermarket electric), & no holes in the fenderwells. Of course, my car doesn't make much HP, either. Scott, I understand since you plan to build another set of headers. I'm sure you will be coating those. They will also last much, much longer with an inside/outside coating. ;) |
Re: LS4 Into an MGB
I wish Doug Brown were still with us. (Really good guy! Sadly, he passed away shortly after attending our 2012 meet.) Doug owned Powder Tech. His guys applied an Electroless Nickel plating to my fuel rail, throttle linkage, etc. Doug and I had also discussed the idea of using the EN on my exhaust headers, after I get around to building them. One big advantage of EN is that it coats the inside and outside of a part equally. Traditional plating leaves the insides of tubes with little or no protection. As I recall, Doug felt that the EN coating would protect my headers very well indeed. However, the color of the headers would be affected by heat. (I think I recall him saying that they'd yellow more than my fuel rail, etc. Typically the Harley Davidson crowd won't accept yellowed chrome, but I couldn't care less.) EN should be significantly cheaper than conventional chrome plating. It doesn't have the environmental issues, and thus the waste disposal costs. The key to a pretty coat of chrome is prep - lots of polishing labor beforehand and more between layers - and chrome shops generally want to keep polishing in-house so they can control quality and also make more money. With EN, you'll probably do nearly all your own prep and there's only one layer. The shops that do EN are typically less concerned about getting a show quality finish, and more concerned about meeting industrial performance requirements. We also talked about how EN could be applied before a ceramic / powder coat coating. When I finally get around to building a new set of headers, I'll look into EN again and let you guys know what I find out.
Re: LS4 Into an MGB
Carl, I used Tech Line's Cermakrome on my headers. They were blasted with glass beads after curing in an old kitchen oven. Came out sort of a semi-gloss finish. Five years old with no issues yet.
I also used their PowerKote on the piston tops and combustion chambers (Rover 3.5) and their Dry Film Lubricant (DFL) on the cam, bearings and piston skirts. |
302V8 Pete Mantell Sidney, IL (96 posts) Registered: 10/23/2007 09:47AM Main British Car: 69 MGB 302 V8 Ford 302 '347' stroker 505HP 440ftlbs |
Re: LS4 Into an MGB
Your LS4 conversion is looking fantastic Scott ! Well done.
Keep the photo's coming........... Cheers Pete |
Re: LS4 Into an MGB
As we're discussing header coatings I don't think this is much off topic. I'm having my headers ceramic coated and was told even with a coating the heat has to go some place...well, that sounds reasonable to me. Apparently the hot spot is where the header connects to the exhaust pipe which is in the area of the front wheel and brake area. Has anyone experienced a problem with this or is the powder coater just being couscous?
Paul |
Re: LS4 Into an MGB
You will have a hot spot somewhere down the pipe past the header, I don't know for sure if this happens with equal length headers though and may check that out later. Anyway the hot spot is where you put your crossover pipe if you have one. The ceramic coating heat shield effect is enough to make the difference between an instantaneous burn on contact, and being able to pull away unharmed.
Scott68B Scott Costanzo Columbus, Ohio (569 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
Re: LS4 Into an MGB
Got back out to the garage yesterday, finally! I was a little under the weather with a virus last weekend although I did get some work done on the wiring harness. As you can see below, I got the right hand side manifold fabricated and about halfway welded together.
I'm about 2/3 done with the exhaust at this point and the most of the time consuming fabrication has been completed. I hope 1 or 2 more sessions will get it there. |
Re: LS4 Into an MGB
Scott, those headers look good enough that you may decide not to replace them! Most would be quite thrilled with what you have constructed.
hirot Ian Hart Ashbourne UK (88 posts) Registered: 06/01/2011 05:15AM Main British Car: 1971 MGB GT (conversion) Rover 3947 R380 gearbox |
Re: LS4 Into an MGB
Paul, I wrapped mine, I don't think we do coating (easily) over hear yet. The headers are wrapped to the bottom of where they all join together. Initially I didn't wrap where the 4 pipes join at the top and the point between the pipes glows cherry red....worrying....wrapped that bit quickly.
The exhaust/header joint doesn't appear to go red or get too hot. However, you don't half get hot feet when you stop in traffic and I mean hot. I wrapped the brake/fuel pipes and wiring near the headers using the slide on tubing and all seems OK. You can hold the headers when the engine is hot. Still not sure whether it was all a good idea in that I reckon the headers will corrode/crack as all that wrapped heat isn't healthy. Scot your conversion looks wonderful. Ian |
Re: LS4 Into an MGB
Question Scott?
Where you engine is mounted now, would there be enough room to run the header collector, down along the frame rail along with the primary tubes? I'm going to attempt this if it is possible with our GT! |
Re: LS4 Into an MGB
Calvin,
Interesting question. Quick answer is no. Where the engine is sitting at the moment, I don't see how you'd find room for 4 pipes in any configuration. Believe me, I HATED cutting into the fender well so I thought long and hard about how it could be done. I believe I could have snaked a 2 inch pipe between the starter and the motor mount on the passenger side but only just...I don't believe a 2.5 inch pipe would fit. On the driver's side, depending on where you place your steering, there is a bit more room along side the engine. I considered building something similar to what I have now and routing the header pipe around the outside of the steering shaft and then down and out the bottom. In the end, it would have taken more time to do that and if I ever hoped to go to a real set of headers, I would have to go through the fender well anyway. That's how I ended up where I am. It might be possible if you moved your engine rearward another 3 or 4 inches and went with head mounted motor mounts. You would still have to get creative with routing your header pipe though and you might have to go with a smaller diameter header pipe than you'd like to get it all to fit. I think it's one of those things where you'd have to try it to see if it would work. I'd be very interested to see what you come up with...hope you share some pictures with us.:) Scott |
