robert1839 Tristan Cook 5579 Timber Ridge Dr, Mt Vernon, Skagit, Washingto (118 posts) Registered: 05/06/2013 11:11PM Main British Car: MGB GT 1972 Buick 215 |
Re: why would you buy a 1975-1980
yes the stanless steel looks good there
how did u make the engine bay cool better? |
kayakjack John Renaud Michigan (35 posts) Registered: 10/23/2007 01:46PM Main British Car: 1980 MGB V8 Buick/Rover 3.5L |
I reworked the firewall by the engine rh cylinder head to get better airflow in to the trans tunnel. The trans tunnel was raised about 3/4 inch from firewall to a few inches in front of the shift lever opening. Around the "thru the apron" headers, the clearance holes are pretty large compared to most installations. The aluminum radiator was moved as far forward as possible & I made an aluminum surround to force all air thru the rad. There is also a u shaped panel from the frt spoiler to the radiator to keep engine heat from getting in front of the rad. Look thru the photo galleries. You will see many approaches to cooling.
Nicely done John.
It's good to see someone who understands the airflow aspect of engine cooling. And put it into practice. Very tidy looking car. Cheers Fred |
