Re: MGB build for speed events - Australia - V8 conversion and lots more
Thanks for the kind comments. It was a labour of love (and money).
The car is about as together as the photos show, but work is back on in anger and i'll post progress shots. The flares are from Paul Trevathen and I'll be tackling the rears this month I hope. I need to box in the rear chassis rails as we cut them in half originally to give us more tyre clearance (pics shortly). I'm cutting the rear part of the rear guard to it follows the panel at the side of the boot. This allows a nice big raised area for airflow, which means only the front part (wraps around the sill I think) is going to affect ground clearance. I'm not sure what you mean "Rear clearance was tough while trying to keep the monocoque together under the flares". I'm about to embark on this and would like to understand if there's something I'm missing or a pending mistake. All up it was designed to have 100mm which is minimum for road clearance. We might be able to drop it a little more for the track, but I'm not sure how much vertical adjustment there is. I'm probably better retaining some clearance in the chassis and dropping the spoiler/splitter lower. I also can now have a side exhaust which gets rid of the big muffler and clearance issues around the diff. I may need a muffle and I see they make flat rectangular ones which hopefully won't destroy ground clearance. I think they are only as thick as the chassis rails. I should not the photos are old and I can take new ones of anything anyone is interested in. Cheers Byron |
This is what I mean by the monocoque connection to the the flare. As you can see I cut the inner wheel well, which is structural, and fanned it out and then welded it to my flare so that my flare is structural. Well the clearance problem, and I have 8 inch wide wheels in the rear, is the outer edge of the tire hitting those fanned out and welded pieces. So my ride height is limited by this tire contact point, I have it set just high enough for the suspension to travel without hitting. Basically I would need to tub the inner fender (and shorten axle) or fan the wheel well more and make the flare larger to decrease my ground clearance.
There are a few more pics under my "how its done" [www.britishv8.org] |
Don't forget your tire clearance will change if one wheel is up and the other is down. Also allow for sidewall flex.
Ok yea I see you have done a lot more cutting than I had originally thought so what I was saying is irrelevant. I like how you tied the cage into the frame, that whole area looks really strong and well thought out.
Good points Jim. The tyres are 18" so sidewall flex will be minimal, but the side to side issue needs to carefully checked. It was always tight and my hope is that the flares will give me plenty of room. A rough fit up shows about 2" extra clearance which should allow an 11" rim with a spare inch. I shall see.
Ivan, all that cutting is great in terms of clearance but it's a pain to reconstruct (and I'm only just starting). The cage etc is great, however I have to get parts of it redone to comply with the latest regs. I've worked out how I can do that by leaving the bar you see and the cross bar for the top shock mount. I can then replace the main rollover hoop , cross brace, and the rear mainstays. The current mainstays aren't straight (slight dogleg) and they are meant to be, mind you I can't see how they can, given they have tie into a certain point on the main hoop and the only place to put it (and keep the angle right) is where they are now on the chassis rail or further forward. I'll see when I talk to the cage guy in a few months. For now, there's work I can, and whilst I'm motivated I'm maintaining the rage! I have lots of pics of this, but it's a it boring. I cut out a plate for the chassis rail yesterday and need to clean it up for an exact fit and bend it slightly in 2 places. And next week I'll have power for the welder so I can start making a mess. I also cleaned up some of the paint around the tail lights and discovers so much filler that it amazes me how poor the build quality was, mind you I don't know if they car was ever in an accident. The car is straight as we checked when it got the sills done, so it doesn't matter. I also discovers some rust. There is rust hole at a join near the tail light, but I can rust convert and fill with weld I think. There is a few other bits of rust, I can see oodles of it high up under the guard but it looks to be surface only, so apart from access to clean up it looks pretty good. I did discover the graffiti wheel I'm using doesn't get that black tar stuff off very week. I was thinking of trying paint stripper. Byron Edited 1 time(s). Last edit at 05/10/2014 07:08PM by choppedfish. |
I'm delighted that you're continuing this wonderful and inspirational project!
