Re: MGB build for speed events - Australia - V8 conversion and lots more
I have one new front guard and one old so decided to get the old one blasted. I have a rust repair section for the rear of this fender so if I screw up I can replace it.
I knew it had some rust repair but it ended up not too bad. There is a section that was cut out and filled and a weird hole on top, plus the lower rear lip is rusted. I was pondering going fibreglass front guards but the spoiler mounts to the guards so it can't be fibreglass and by the time I finish there won't be much left. I'm planning to cut the entire rear section out just above the seam line in the panel and then rivet in an aluminium section to funnel the air out like the cars below. This removes the bulk of the rusty section and removes weight. The folded in section can't go all the way to the door as there is an internal panel that holds the back of the guard to the body. But that is fine. I will put a vent/louver like the ones here which will very nicely cover that weird hole. [elianmotorsport.com] |
