Goto Page: Previous123
Current Page: 3 of 3
choppedfish
Byron Anderson-Lister
(45 posts)
05/02/2014 02:05AM
Re: MGB build for speed events - Australia - V8 conversion and lots more
Posted by: choppedfish
Date: May 05, 2024 12:33AM
The next task was the firewall on the drivers side.
It was made with 2 removable sections and a lid for 2 main reasons. The first was to allow the headers to be put on with the engine in the car as I'm not sure the engine can go in with them on. It also gives more clearance so the engine can go in with them on.
The second was the lid that allows access to the top of the pedal box for adjustment of the master cylinders and also access to the brackets holding it in. If it wasn't removable there is no way we could ever get the pedal box in or out.
Edited 1 time(s). Last edit at 05/05/2024 12:34AM by choppedfish.
choppedfish
(45 posts)
05/02/2014 02:05AM
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: July 09, 2024 08:09PM
Many many hours of work and I have closed in the top section of the cage.
I made curved bars to match the rear section near the boot, which was a pain to get right. I then made little brackets all the way around the outside.
Lastly the aluminium top sheets were done in 5 pieces as there is very little access. The infill pieces will be riveted in.
We are thinking British racing green as the body colour and with stainless bolts gives it a sort of riveted look. Perhaps.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: July 09, 2024 08:17PM
Then it was time to close up the vertical section. This wasn't too hard but after installing 78 rivnuts on the top section I knew it would be fiddly. Especially getting the bend in the lower quadrants exactly correct.
So there are 4 quadrants, the top quadrants connect to the curved bars. The lower connect to basic brackets welded along the bottom and side, with a bar across the car to connect the top and bottom together. As always making the panels was easy, the drilling, rivnutting took many hours. That and the 90 degree bend in the left hand lower quadrant. I wanted it to be exactly the same height as the right. That took about 4 hours and 50+ measurements before I was confident to do it.
Now onto the trans tunnel which should be easier.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: July 14, 2024 12:53AM
The tunnel and passenger firewall is now done. Looking like a finished car more and more.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: July 16, 2024 03:12AM
Both rear flares are on.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: August 01, 2024 12:57AM
I have one new front guard and one old so decided to get the old one blasted. I have a rust repair section for the rear of this fender so if I screw up I can replace it.
I knew it had some rust repair but it ended up not too bad. There is a section that was cut out and filled and a weird hole on top, plus the lower rear lip is rusted.
I was pondering going fibreglass front guards but the spoiler mounts to the guards so it can't be fibreglass and by the time I finish there won't be much left.
I'm planning to cut the entire rear section out just above the seam line in the panel and then rivet in an aluminium section to funnel the air out like the cars below. This removes the bulk of the rusty section and removes weight. The folded in section can't go all the way to the door as there is an internal panel that holds the back of the guard to the body. But that is fine.
I will put a vent/louver like the ones here which will very nicely cover that weird hole.
[elianmotorsport.com]
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: September 23, 2024 09:49PM
And both sides are done.
The front flares are not identical, nor are the wings/fenders but everything is as exactly matched as I can do.
The louvers are from Professional Awesome as they were bigger and cheaper than racing louvers.
Now onto brakes.
Edited 1 time(s). Last edit at 09/23/2024 09:50PM by choppedfish.
almimono
Almi Frank
(2 posts)
06/29/2023 08:00AM
Posted by: almimono
Date: November 07, 2024 08:06AM
Interesting thread, nice builds!
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: January 01, 2025 07:38PM
Thank you.
Lots of updates;
1) Brake hard lines run. Will do flex lines down the track
2) Dry sump pump rebuilt from single stage back to 3 stage. Had to reinforce the rear of the pump to stop flex.
3) Dry sump tank mounted
4) Mocked up front brakes with Porsche big red adaptors. Have since bought 2 piece rotors to fit different hats so offset is correct.
5) Fuel tank made and straps fitted
6) Lifter pump bracket made
Now onto mocking up fuel lines etc.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: January 01, 2025 07:44PM
Dry sump pump. It had to be rotated on its mount to allow the returns to clear the sump. Sump will likely need to modified as well down the track to put in more pickups.
Front brake mock up.
Dry sump tank mounted. Can be accessed via small panel in the section behind the seats.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: January 01, 2025 08:00PM
Fuel tank mounted. It's about 81.5litres but due to the angle of our modified boot floor we will need to have the car jacked up to fill it that much. Should be good for 30 minutes of racing.
Lifter pump mount. 2nd photo is a reinforcement to stop it wobbling too much.
Edited 1 time(s). Last edit at 01/02/2025 08:01PM by choppedfish.
choppedfish
(45 posts)
05/02/2014 02:05AM
Date: February 12, 2025 09:47PM
Fuel system is complete. As it's mainly push on fittings I've left one end off for now as it will all need to be removed for painting etc.
Edited 1 time(s). Last edit at 02/13/2025 09:26PM by choppedfish.
