Goto Page: 12Next
Current Page: 1 of 2
(6569 posts)
Shift paddles
Date: February 05, 2015 01:39PM
How about a little bit of Titanium?
Inside shot shows the location of the capacitive touch sensor card, the backing plate, and behind the card you can see the edge of the LED window:
Outside view of the LED window. They light up during the pulse output to the transmission controller.
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Re: Shift paddles
Posted by: Jim Stabe
Date: February 05, 2015 02:31PM
Now that's pretty cool! How much movement does it take to make it shift?
(6569 posts)
Re: Shift paddles
Date: February 05, 2015 02:59PM
Less than zero. :-)
It can pick up a finger from 5-10 mm away. Even through gloves.
Edited 1 time(s). Last edit at 02/05/2015 03:02PM by BlownMGB-V8.
(4636 posts)
Re: Shift paddles
Date: February 05, 2015 03:31PM
You post the most interesting and thought-provoking things!
I think I understand the paddle design pretty well. (Fixed paddle position is so much simpler than having them move with the steering wheel. Apparently that decision drove you to make each paddle cover a wide angle.) However, I don't understand what you've posted about an LED window. Are you saying there's a display to tell the driver which gear they're in? Or to advise that a gearchange is recommended? Or...?
(4636 posts)
Re: Shift paddles
Date: February 05, 2015 03:34PM
5-10 mm away. Neato! But will sensitivity be easy to adjust? If it detects your hand when you reach for the turn signal stalk...
(6569 posts)
Re: Shift paddles
Date: February 05, 2015 06:38PM
The stalks are well outside of the paddles (which have a 9-1/4" outer diameter). Each paddle is connected to one sensor circuit. (Two circuits on one card.) Each sensor circuit outputs a grounding pulse when a touch is sensed. Each output has a board mounted LED that lights during the grounding pulse and the window allows you to see that the board is generating an output. Won't be very visible when driving unless you intentionally look at it but useful for troubleshooting if needed. Since the LEDs were there I installed a window for them made out of smoked plexiglass. The same stuff I'll have over the gear position readout.
Speaking of which, I have a 7 segment LED numerical readout and driver chip which I am embedding in the stock (modified) brake warning light and switch. The bezel isn't quite deep enough but the fit is good otherwise. It's an old bezel though and like most of them the silver is gone. I may paint it black. Anyway the indicator light is now an LED and is hooked to my WB-O2 sensor. I installed a micro tactile switch to replace the old contacts and have the button between the red lens and the 7 segment display. That is the calibration switch for the O2. Then the display sits on the right end of the bezel and I cut off the black rocker and squared it up to match nicely with the smoked window. Still some work to do to finish it up and connect the lead-out wires. I got an AMP CPC series 9 pin connector for it which should fit through the cutout with just a smidgen of dressing down of the back shell.
So yes, I will have a digital gear readout, 1 through 8, blue, with 0 for neutral and park and flashing for reverse. Maybe a flashing 9 or else zero, I haven't decided yet. Maybe a flashing 8. The display also has a separate lead for the decimal point, so I have another built-in LED indicator I can use for something else if I want to.
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
1966 MGB V6 1994 Camaro 3.4L 60V6
Re: Shift paddles
Posted by: Charles
Date: February 06, 2015 12:08AM
Jim, neat. Are you going to have false shifts when you get your fingers to close ? I would be forever shifting up and down because I am forever flexing my fingers.
You going to bring the car to Indy ? I think a lot of us would like to see/hear it.
charles
Dan B
Dan Blackwood
South Charleston, WV
(1009 posts)
11/06/2007 01:55PM
Re: Shift paddles
Posted by: Dan B
Date: February 06, 2015 10:32AM
Can you turn the paddle shifter off if you want to be lazy, or let someone clumsy like me drive? Also, using the 8 for reverse might be good... it has the elements there to make an R.. Is that possible? An 8 kinda looks like a B, for Backup
(6569 posts)
Re: Shift paddles
Date: February 06, 2015 10:41AM
My LE steering wheel is 14-1/4" diameter so that puts the paddle 2-1/2" inside the steering wheel and it's also set back about 2". It's a short reach for sure, but unless I have fingers flying off the back side of the wheel I'm not going to hit it and maybe not then. Right now I'm a little more concerned about the possibility of flashing the headlights getting the stalk close enough to trigger a downshift. But it might not be a problem as the stalk is not grounded.
I'm expecting to have the car back on the street shortly after the weather breaks but whether or not it's ready for Indy depends on more than just me so I can't make any guarantees yet. Still have a few issues to deal with but we'll see. It'll be there if possible.
(6569 posts)
Re: Shift paddles
Date: February 06, 2015 10:47AM
The car should run in standard Auto mode unless you touch the paddles. Then I think there is a time interval that can be set for manual mode that will time out whenever I set it to. There is also an input to select Auto or Manual mode but I haven't done anything with that yet. Might be handy for stop and go traffic. Maybe I should hook that up.
(6569 posts)
Re: Shift paddles
Date: February 08, 2015 12:42PM
Installed and tested:
Dan B
Dan Blackwood
(1009 posts)
11/06/2007 01:55PM
Re: Shift paddles
Posted by: Dan B
Date: February 08, 2015 12:44PM
Cool! No problem with the dimmer switch?
(6569 posts)
Re: Shift paddles
Date: February 08, 2015 02:11PM
Nope. None at all.
cgill
Chris Gill
Salmon Arm, British Columbia
(129 posts)
08/13/2009 12:06AM
1979 MGB roadster Buick 300 stroker with EFI
Re: Shift paddles
Posted by: cgill
Date: February 10, 2015 05:53PM
Jim. That is amazing!
Dan B
Dan Blackwood
(1009 posts)
11/06/2007 01:55PM
Re: Shift paddles
Posted by: Dan B
Date: February 10, 2015 08:01PM
I just want to play with them!
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
Re: Shift paddles
Posted by: Charles
Date: February 10, 2015 09:30PM
Dan , I am sure you are thinking about plying with the shifter while under power.
charles
Todd McCreary
Todd McCreary
(210 posts)
03/16/2012 10:57PM
Re: Shift paddles
Posted by: Todd McCreary
Date: February 11, 2015 01:49AM
[www.youtube.com]
people who play Tesla coils are normally more into heavy metal.
(6569 posts)
Re: Shift paddles
Date: February 12, 2015 06:37AM
Got a U-tube link for the tesla coil players?
(4615 posts)
Re: Shift paddles
Date: February 12, 2015 10:06AM
Or Southern Rock. ;)
[www.youtube.com]
(6569 posts)
Re: Shift paddles
Date: February 12, 2015 07:21PM
Well ain't that sumthing.
Goto Page: 12Next
