MGB - inner fender template to cut holes for RV8 style exhausts
Hi guys - getting round to cut the holes in the inner fenders for the RV8 style exhausts to exit and wondered if anyone had a template / approx measurements to save me from getting it wrong and performing my normal "hatchet job"
Cheers - John (75 B) |
Re: MGB - inner fender template to cut holes for RV8 style exhausts
John, there are so many variables you probably need to provide more information -- like whether you have a BOPR variant motor or something else & whether the motor mounts & headers you used came from one of the typical suppliers. Even with that it may be a long shot.
Simon Austin Simon Austin Surrey, British Columbia (107 posts) Registered: 10/23/2007 01:44AM Main British Car: 1977 MGB V8 / 1970 MGB GT V8 project Rover 3.5 / Rover 3.5 |
John,
If it helps you out, when I had the holes cut for my RV8 headers, all my body man and I did was have the engine installed and slowly lowered the headers while he cut out (with a plasma cutter) gradually larger holes around the header until the size was correct when the header was in place. Here's a pic of the finished product. |
Thanks guys for replying - DUH!! - where was my brain - yes I should have given some more info like the type of engine (Rover 4.2) / headers type / engine positioning - you are quite correct, quite a few variables as to where the headers will exit.
Great picture Simon - thanks, this gives me a good starting point and yes I think that lowering the engine and working the exit hole from there is perhaps the best approach. Thanks again - John |
Here's a glimpse of what the holes look like on British Motor Heritage reproduction RV8 panels:
Somewhere I have a template for the RV8 header adaptation needed for a BOPR....I'll try to find it.
mgbrv8 David Hetrick McAllen Texas (78 posts) Registered: 03/09/2008 12:49PM Main British Car: MGBs- 1977,1969 Vettes-1965,1984,2003 ZO6 LS1s in MGs |
What fender flars are you running they look great.
Dave |
Thanks all - John
kenzmyth Ken Smith San Rafael, CA (55 posts) Registered: 12/09/2008 10:50AM Main British Car: 1966 MGB Roadster 67-76 Rover 3500S 3.5 Liter Hi Comp #4300000A seri |
Hello All,
I am a new member with a 1966 MGB Roadster V8 conversion project I bought from a friend. He has done all the engine compartment mods and bought RV8 style exhaust headers for the Rover 3500/SD-1 conversion project, so I am keenly interested in those templates for the exit holes. Please let me know who has them and how I might get them. Also, the areas of the engine compartment over the original lever shocks, which need to be modified for clearance, were removed, completely. Since it looks like a fairly complex, compound curved area, anyone have any suggestions for filling them in? I am not a great metal fabricator, so I'm wondering if there are engine compartment sheet metal replacement parts available. Moss Motors doesn't carry them. Thanks, Ken. |
Ken, send a pic of the area you need. I got the inner fenders from a car that was being parted out; if the part you need isn't the part I'm using, you can have them for the cost of shipping.
