limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
Rebuilt 1994 WC T-5 slight fluid leak
Posted by: limey222
Date: August 12, 2015 10:17PM
Sigh....just got my 93-95 GM 3.4 V6 engine and T-5 installed in my 1969 along with a new 18 gal aluminum gas tank plus all the new wiring and plumbing.
I had the car taken over to an exhaust shop this morning for a new system and when I get it back home I plan on starting it for the first time.
While on the hoist at the shop I noticed a small drip forming on underside right where the gearbox mates with the extension housing. Should i be worried?
The guy that did the transmission rebuild had good reputation, should I try gently to see if I can tighten the bolts a little more or is that now a lost cause.
I really don't want to have to pull the whole set up back out again. I filled the transmission through the shifter opening and at the 3 quart mark there was nothing coming out of the level hole.
(1389 posts)
Re: Rebuilt 1994 WC T-5 slight fluid leak
Date: August 13, 2015 12:33PM
Is there any possibility of spillage when you filled it?
It may have just followed the seam down to the bottom of the trans.
tomsbad6
Tom Ahlstrom
Michigan
(129 posts)
12/16/2012 03:16PM
Triumph TR-6 347 Ford
Posted by: tomsbad6
Date: August 13, 2015 06:58PM
t5 trans takes just a little over 2 quarts any more thay leek 2 quarts is all I ever run
(4626 posts)
Date: August 13, 2015 10:13PM
Lots of us run close to 3 quarts without issue. Once upon a time there was a GM service bulletin that instructed techs to add more fluid.
(1389 posts)
Date: August 14, 2015 12:18PM
Yep.
The official fill level is 2.8 quarts according to my gm info.
FLIPSMGV8
Phillip Quinn
Reidville, SC
(15 posts)
04/21/2010 10:01PM
1978 MGB Rover 3.9 V8
Posted by: FLIPSMGV8
Date: August 16, 2015 05:56PM
My T5 trans took just about 3 quarts before it started to run out the fill hole but my tranny is not a WC. I have only put a few hundred miles on it and as of now it seems to be ok. I'm still working out a few bugs but she sure runs better with this engine than I expected. Michael when you get her going it's going to be about more fun than one should have.
limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
Posted by: limey222
Date: August 16, 2015 11:25PM
Phillip, thanks for the encouragement, I need it with all the problems I am experiencing, see my other posts. At least the engine seems sound, 75 psi oil pressure at start in 80 degree weather, dropping down to around 70 when engine is hot.
rubbinisracin
Ivan Collins
(38 posts)
03/19/2013 09:34AM
Posted by: rubbinisracin
Date: August 17, 2015 09:07AM
I noticed your post about the HTOB. Did that HTOB require the shaft collar to be replaced? If so, it's quite possible that your leak is coming from there. I have an HTOB and have been battling a leak in that area. Just a thought.
