gstock
Gareth Stock
(1 posts)
10/12/2015 05:22PM
1987 Mark VII Donor Car for MGB V8
Posted by: gstock
Date: October 12, 2015 10:36PM
Hi,
I'm new to the forum and am looking for some advice.
I've got an old 1987 Lincoln Mark VII that I've had in the family since it was purchased new by my Grandmother. The unibody rusted out so bad that there's no saving it. I'd like it to live on as a V8 MGB.
I'm going to be pulling the engine out of it this upcoming weekend before sending the car off to the wreckers. Can anyone here comment on what additional parts I'll need to keep from it?
1) Engine and all associated wiring, computers, etc.
2) Tranny (automatic, but hoping to sell and get a T-5)
3) Rear End (I've heard the stock MG rear ends can handle the extra power, but if I have it should I swap it anyway after having it shortened?
Thanks,
Gary
63BlueMGB
Nick B
Kansas City, Mo.
(92 posts)
01/16/2011 05:17PM
1963 MGB
Re: 1987 Mark VII Donor Car for MGB V8
Posted by: 63BlueMGB
Date: October 14, 2015 12:56AM
Hi Gareth,
Welcome to the forum!!! I actually used a 1990 Lincoln Mk VII LSC for my Donor to build my MGB. Here is what I kept and a couple of things that I forgot that I wish I would have.
1. Engine and accessories
2. Transmission, (mine was an automatic, which I sold, and bought a T-5
3. EFI harness and Engine harness and CPU
4. Throttle cable
5. Starter or remote solenoid
6. MAP or BAP sensor, located on the firewall which is attached to the intake manifold
7. Charcoal Canister for fuel vapor line, Charcoal canister solenoid
8. EGR solenoids should be 3 of them
9. Driveshaft to be shortened and uses the same spline for the manual t-5
10. Rear end and Brakes, also emergency brake lines
11. Fuel pump, it can be modified if you would like for a submerged fuel pump
12. Connector for the Alternator
13. Battery even if bad, you can use it for the core charge when buying a new one
14. Exhaust system, you can sell the catalytic converters separately to scrapper and possible reuse mufflers if they are still good
15. Wheels for rolling your car around until you buy new ones
16. Fuel pump relay and relay block and actually all relays
17. Fuel inertia switch located in the trunk
18. all electronic modules from the inside if they work, they can be sold on ebay for other mark vii owners
19. voltage regulator
20. ignition coil and spark plug wires
That is all I can think of at the moment. Hope this helps and good luck on you build. If you are curious on mine it is in the project journals under NB 63 MGB
