limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
93-95 GM 3.4 PCM fan temperature values
Posted by: limey222
Date: October 14, 2015 01:30PM
Can anyone confirm that the stock PCM for these years sends a command to turn the fan on at 223 degrees F and back off at 185 degrees F?
I am reading this out of the 1994 GM factory Service manual (book 2 0f 2), am I interpreting this correctly?
Scott68B
Scott Costanzo
Columbus, Ohio
(569 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Re: 93-95 GM 3.4 PCM fan temperature values
Posted by: Scott68B
Date: October 14, 2015 06:22PM
Michael,
If you're using the PCM to control the fan it's an easy thing to confirm yourself with an infrared gun. The PCM takes feedback from the coolant temperature sensor and the GM CTS isn't known for being real accurate. Probably not a bad idea to check just so you'll know.
limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
Posted by: limey222
Date: October 15, 2015 02:33PM
Well i purchase an infrared gun and I wasn't far off. The electric fan definitely turns off around 185 F. The top limit for turning on was a bit sketchy, seems to be around 220 F even though the temp gage was reading around 225-230 F. Evans waterless coolant boils around 350+ F so the only concern would be oil temperature since I don't have an oil cooler installed.
(4629 posts)
Date: October 16, 2015 10:27AM
O course, that gun is only reading surface temps. Also, the the readings will be off based on what it is pointed at because of emissivity. Doesn't work as well on shiny objects. You can add a spot of flat black paint that can be cleaned off later.
