BOOTLEG
Gary Rosema
Wisconsin
(47 posts)
11/18/2013 07:26PM
1978 MGB Rover 3.5L
rocker switches
Posted by: BOOTLEG
Date: December 19, 2015 07:57PM
Has anyone found a supplier of robust black rocker switches that fit nicely in the stock dash cut outs?
I mounted my new Advance Autowire panel and would like to install the cooling fan, hazard and fuel cutoff switches mentioned in Dan's instructions.
Re: rocker switches
Date: December 19, 2015 09:33PM
Moss, Victoria British, and others sell the OEM style ones.
MGB567
Barrie Braxton
(38 posts)
04/26/2015 12:13AM
Re: rocker switches
Posted by: MGB567
Date: December 20, 2015 03:12AM
IDK which dash you have but I'm likely to fit Durite rockers to my (UK) '79 dash.
BOOTLEG
Gary Rosema
Wisconsin
(47 posts)
11/18/2013 07:26PM
1978 MGB Rover 3.5L
Re: rocker switches
Posted by: BOOTLEG
Date: December 20, 2015 07:10AM
MGB567,
My 1978 B has 4 rectangular locations which measure ~28.7mm X 22.1mm. The Durite rocker online is 19.5mm X 13mm. Are there others which provide a tighter fit?
BOOTLEG
Gary Rosema
Wisconsin
(47 posts)
11/18/2013 07:26PM
1978 MGB Rover 3.5L
Re: rocker switches
Posted by: BOOTLEG
Date: December 20, 2015 07:25AM
Rob,
The problem I'm having with the OEM switches is I can't find the 3 position for the (manual, off, auto) functions Dan describes for the cooling fan. Any thoughts there?
Thx.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: rocker switches
Posted by: ex-tyke
Date: December 20, 2015 10:16AM
Isn't the '78 heater blower switch a 3 position (Off - Low - High) ?
(4629 posts)
Re: rocker switches
Date: December 20, 2015 10:46AM
My '79 is.
(6590 posts)
Re: rocker switches
Date: December 20, 2015 12:42PM
I used 3 smaller illuminated rockers stacked 3 high to replace each of the headlight/heater switches. Epoxied each trio together, they also come in black, and then will fit the stock cutout with maybe just a little filing. That gives separate control of the headlights, marker lights, and fogs or driving lights but wiring a 3 speed blower can be a little tricky, especially if you want to light the switches.
For the Hazard I used a standard black handled toggle (more reliable) with a red switch cover and made an insert to center it in the old cutout. Same for an auxiliary radiator fan switch.
This didn't get me sealed connectors or sealed switches, so I cast silicone boots to hold the connectors on the switch trios and more or less seal to the bodies. With relays they have held up pretty well.
DonB
Don Bonar
Prairie Village, KS
(80 posts)
09/09/2011 10:06AM
1971 MG-B 95 GM 3.4 V-6
Re: rocker switches
Posted by: DonB
Date: December 21, 2015 12:41PM
On an earlier project, I used lighted marine rockers from MarineWorks... robust and sealed... just a thought.
Bones
(6590 posts)
Re: rocker switches
Date: December 21, 2015 01:55PM
Good tip Don. Marine wiring has much more trouble with oxidation than we do.
