relative4
Billy Andrews
Denver, CO
(55 posts)
11/25/2008 02:28PM
'80 MGB Rover 3.5
Removing aluminum corrosion
Posted by: relative4
Date: February 15, 2016 12:17AM
I need to replace the timing cover on my Rover 3.5, and I have a spare that's been sitting around a long time. It's never been used, but it has accumulated a bunch of aluminum oxide that needs to come off before I can use it. Any recommendations on a good solution? Hopefully a spray to get into all the nooks and crannies?
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Removing aluminum corrosion
Posted by: ex-tyke
Date: February 15, 2016 10:16AM
Might try good 'ole vinegar for a start. Commercial aluminum cleaners are, I think, muriatic acid based.
Then there are the CLR products that might have a suitable solution.
Edit: If it were mine, I'd get it bead blasted.
Edited 1 time(s). Last edit at 02/15/2016 12:27PM by ex-tyke.
(4629 posts)
Date: February 15, 2016 02:19PM
I'm with Graham. Bead blast it. I have a friend that used to spiff up his aluminum intake with Brillo pads.
relative4
Billy Andrews
Denver, CO
(55 posts)
11/25/2008 02:28PM
'80 MGB Rover 3.5
Date: February 16, 2016 04:23PM
I assumed bead blasting would compromise the mating surfaces. Not so?
ex-tyke
Graham Creswick
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: February 16, 2016 05:01PM
If it's done properly, one can easily avoid blasting the side/mating surfaces.
I've done a few front covers and intake manifolds without any issues.
kstevusa
kelly stevenson
Southern Middle Tennessee
(986 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: February 16, 2016 06:11PM
JUST BLAST IT WITH NUTS! shells :-)
HealeyRick
Rick Neville
(495 posts)
12/19/2007 05:01PM
Posted by: HealeyRick
Date: February 17, 2016 12:50AM
Aluminum deoxidizer: [www.californiacustom.com] and Purple Polish: [www.californiacustom.com]
