T5 Transmission mount rear height?
Hi folks,
I have my RV8 engine and Mustang T5 trans in my 79 B for the first time, and I'm realizing I have some unanswered questions. I can already tell that I have to ease the top of the trans tunnel and remove the stock heat shield to bring the trans up a bit, but I don't know how much it should go up. Using the welded-in crossmember as a reference, when my trans is resting on its rear mount, what should the distance be between the bottom of the tail housing and the top of the welded-in crossmember? Or should I be measuring the angle of the trans somehow? I'm using D&D engine brackets with standard circular RV8 mounts. With a D&D bellhousing spacer, the ford T5 rear trans mount sits directly above the stock B trans crossmember. I plan to cut off the stock trans brackets on the MGB crossmember and adapt a stock mustang trans mount to fit. Edited 1 time(s). Last edit at 06/11/2017 09:04AM by RDMG. |
