RE: Article- http://www.britishv8.org/Articles/EFI-Fuel-Tank-Mods.htm
Some questions on soldering - Which type of solder is appropriate ? Silver solder , tin-lead , or will no lead plumbing solder work . I presume that flux is required since the flange is not "tinned" like the ni-terne coated tank ? Use a stanadard propane torch vs MAPP ? - Thanks
Edited 1 time(s). Last edit at 12/07/2008 11:14AM by petepeters. |
