Buick 215 V8 oil pressure gauge options
When the Buick 215 V8 is installed I understand the oil pressure gauge will not read correctly. What options are available? I want to keep the stock look of a 1978 MGB.
MGBV8 Carl Floyd Kingsport, TN (4014 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Re: Buick 215 V8 oil pressure gauge options
The oil pressure gauge will read with the same accuracy as before. I still use all my stock gauges in my '79 BV8.
You will need to mod your tachometer. Easy to do following this article below. Be sure & read the correction at the bottom of the page. [www.britishv8.org] |
