howellmail jeff howell Birmingham, AL (1 posts) Registered: 12/29/2008 06:34PM Main British Car: 1963 MGB Roadster 1963 Buick 215 |
Speedometer for 63 MGB
Does anyone know of a vendor who can supply a electronic replacement speedo for a 63 MGB that looks like the original? My existing speedo locked up and was never correct on the speed anyway.
Re: Speedometer for 63 MGB
Could try these guys to custom make one: [www.redlinegaugeworks.com]
We have used these guys for years:
[gaugeguys.com] Any electronic gauge is going to not have a mechanical odometer and may not have the jewels in them for things like turn signal, charge lamp or high beam indicator. If you contact them, they can give you a number of options. None will be as cheap as just installing an aftermarket gauge, but if matching the stock units makes a difference to you, then the cost is worth it. -BMC. |
302V8 Pete Mantell Sidney, IL (96 posts) Registered: 10/23/2007 09:47AM Main British Car: 69 MGB 302 V8 Ford 302 '347' stroker 505HP 440ftlbs |
Jeff,
Give Roger a call at Speedometer Service Company 414-463-6660. www.speedometersolutions.com They should be able to help you out. Cheers Pete |
Maybe I'm missing something, but assuming you still have the 4 cylinder, the 63 would have a mechanical tach. Just buy a tach out of a 65 - 68 and it looks identical but is electric.
Oops, sorry, reading to fast, saw 'tach' for speedo and wondered what the problem was.
Now If I could just figure out why my electronic speedo refuses to register on the Jamaican. It has a V8 T5 in it - guess the first thing to do is pull the wires and drive it and see if there is any juice? Make sure the sender is working. |
